403 engine
Old Nov 7, 2019 | 08:02 AM
jerryl's Avatar
403 engine
just acquired a 69 442 with 79 403 engine in it, the heads have a "e" on them believe from 455 ,are they worth keeping ?car was in a barn for 37 yrs motor turns by hand. hope to get started soon redoing fuel delivery system and wiring right now. was told motor rebuilt but not ran, heads were supposedly milled. when I enlarged pics found they are e heads not d ,sorry
Old Nov 7, 2019 | 08:12 AM
Magna86's Avatar
I see you double checked and found they were E heads. Yes they are fine and worth keeping. Makesure you soak the cylinders with ATF and rotate the engine over by hand without the plugs incase it maybe stuck. You will also want to removed the distributor and spin the oil pump with a drill to get oil flowing to all the engine parts before you try and start. It will help prevent damage from being dry and sitting so long.
Old Nov 7, 2019 | 08:39 AM
jerryl's Avatar
don't know how to send pics from phone to this site,but when I figure it out I will send pics.
Old Nov 7, 2019 | 12:00 PM
E heads were used on the non W-30 1970 455 engines and are one of the better big block Olds factory heads.
Old Nov 7, 2019 | 07:08 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
They may be other goodies in the motor if someone bothered swapping heads.
edegraaf
Nov 16, 2016 08:01 AM
pnewt50
Aug 2, 2016 07:02 PM
J-(Chicago)
Feb 26, 2014 09:14 AM
majcutlass
Apr 17, 2009 11:45 AM
