DIY 350 on a budget
Old Mar 4, 2012 | 11:43 AM
boondocker's Avatar
Where were you in '72?
DIY 350 on a budget
I've been meaning to get a sound/video clip of my 350 build ('72 Cutlass 442), she runs fantastic, I start up once a week and vary the revs. The car is fully mechanically functional, I step into it and the wheel spins till I let off. I will post the complete build once I get a little further into it, because this is a slow build.
- bored .30
- 10/10 crank
- moly rings
- autotec forged flatop pistons
- FM bearings (cam, mains, conrod)
- Comp cam XE262H, 218/224 @.50 on 110, .475/.480 lift
- Comp springs (100lb) and H lifters
- valve guides (brass), seals (HP), 3 angle VJ, resurface 5K
- new oilpump, waterpump, timing set
- '77 Qjet rebuild (CR HP kit)
- power steering rebuild kit
- new fuel and brake lines (double flared)
- new brake cylinders
- body bushings
- Hotchkiss rear suspension
- converted front disc brakes
- converted bench to console buckets
- complete trunk replaced (from rear floor back)
Still have the body work to finish (I see this as the biggest job), doors are finished (new metal and hinge kits) and the interior. I'm trying to refurbish most of the original equipment including the gas tank (soon to be installed), in the video I'm running from a 5gal. fuel can sitting on the front passenger side.
http://s1054.photobucket.com/albums/...t=DSCN0966.mp4
Old Mar 4, 2012 | 12:52 PM
Lets get some pics up and show the progress on that 350! I need some inspiration.....
Old Mar 4, 2012 | 01:49 PM
boondocker's Avatar
There's a video in the op, but I've got scattered pics of the build...unfortunately I wasn't documenting as well as I should have.
Old Mar 4, 2012 | 01:54 PM
boondocker's Avatar
...more
Old Mar 4, 2012 | 02:02 PM
boondocker's Avatar
...more, I put a Transgo shift kit in but had problems with the valve body (seized 2nd to 3rd), managed to get a junker out of Colorado...tires squeel in 2nd.
Old Mar 4, 2012 | 02:38 PM
boondocker's Avatar
Chassis, sand blasted, chemically treated, primed and chassis paint.
Old Mar 4, 2012 | 02:45 PM
boondocker's Avatar
...more, few body work pics, used bits from a donor car and some new YearOne stuff.
Old Mar 4, 2012 | 02:54 PM
boondocker's Avatar
...more
Old Mar 4, 2012 | 02:59 PM
boondocker's Avatar
...more
Old Mar 4, 2012 | 03:10 PM
boondocker's Avatar
...and
Old Mar 4, 2012 | 03:18 PM
boondocker's Avatar
...and some more, painted dash pad, cleaned up the few parts that i'm not replacing from the interior.
Old Mar 4, 2012 | 03:23 PM
boondocker's Avatar
...more interior, cleanup the radio, the tape deck needed new belts and a replacement motor drive transistor.
Old Mar 4, 2012 | 03:35 PM
boondocker's Avatar
...more interior, grills were beyond redemption...I sandblasted the front and rear seats.
Old Mar 4, 2012 | 03:45 PM
boondocker's Avatar
When it warms up a bit I'm going to start on refurbishing the gauges and the heater assembly (have a new heater core), then onto the body and paint. Despite all the (organized) kaos in my garage, i'm slowly moving forward...
Old Mar 30, 2012 | 04:15 PM
boondocker's Avatar
http://s1054.photobucket.com/albums/...t=IMG_0084.mp4
Old Mar 31, 2012 | 01:57 AM
DENT's Avatar
Lookin real good.
Old Mar 31, 2012 | 02:00 AM
DENT's Avatar
Just wondering , what did you use on the chassis , that green stuff?
Old Mar 31, 2012 | 08:21 AM
boondocker's Avatar
I used self etching primer, then black chassis paint.
deejai35
Mar 10, 2012 08:56 PM
OldsMotion
Sep 12, 2010 09:07 AM
Red Delta
Jan 30, 2010 08:11 AM
boondocker
Dec 4, 2009 10:32 PM
shaks 442 clone
Sep 10, 2007 10:25 PM
