vaccuum advance position
Old Jul 24, 2008 | 08:00 AM
millwrightrice
Guest
Posts: n/a
What position is the vaccuum advance suppose to be in when your timing is correct?I have installed a pertronix ignitor in the previous points distributor.It starts great runs great except for the small miss I think I'm one tooth off.Everything is new wires,distributor,plugs,cap,coil.I did not by the blaster coil for the pertronix could this be a problem.Right now the advance is sitting at the 11 o'clock positon towards firewall seems to far for me.If I try to turn it back towards the valve cover the timing becomes to slow I'm between 8 and 10 degrees right now.
Old Jul 24, 2008 | 11:10 AM
I have a Pertronix ignition in my 64 Olds and I never installed the Blaster Coil. It runs well. You shouldn't change your timing once you install the Pertronix kit. Keep it at the factory spec, unless you are running a radical cam or aftermarket carburetor and intake.
Old Jul 24, 2008 | 10:35 PM
BILL DEMMER's Avatar
Just the facts...
advance it one tooth and you should be good. it should be close to the middle, between the firewall and manifold.
bill
Old Jul 25, 2008 | 08:11 PM
z11375ss's Avatar
Senior Moment Member
I agree. To do this you have to remove the distibutor and stick a screwdriver down the hole and move the oil pump back just a tad. This will give the desired position. I am so particular about this stuff I have to have my vaccuum advance in just the right place where it looks perfect. It will work turned in any position as long as you are firing number one cylinder on number one spark plug wire. You could probably leave it alone and it will work fine. As long as the timing is set to the right advance.
Old Jul 26, 2008 | 03:04 AM
That's correct, except that the Olds oil pump driveshaft is a hex, so I don't think using a screwdriver will do much. It's a 5/16 socket that you need to use. Of course, most people (well, me anyway) just put the distributor in where it needs to go then bump the starter to get it lined up with the oil pump driveshaft.
Old Jul 26, 2008 | 06:01 AM
z11375ss's Avatar
True. I was thinking of that other brand I also own. And bumping the starter till it just falls in is easier.
Old Jul 26, 2008 | 06:38 AM
True. I was thinking of that other brand I also own...
'S OK, we won't hold it against you.
I might have one of those engines in my truck as well...
Old Jul 28, 2008 | 03:26 PM
millwrightrice
Guest
Posts: n/a
Thanks guys I am going to move it because it drives me crazy not being exactly right.Maybe the small miss will stop.
tds
May 7, 2013 10:29 AM
Big Blue 72
Mar 1, 2013 10:49 PM
pcard
Feb 11, 2013 05:09 PM
rloxton
Mar 21, 2010 05:57 PM
drgnbumpr63
Nov 9, 2007 08:47 AM
