timing
Old Jul 20, 2008 | 06:03 AM
cutlassinvt's Avatar
timing
wheres a good place start from when adjusting the timing on an olds 350, is it 10 advanced ;lke the chubbys?
Old Jul 20, 2008 | 08:57 AM
BILL DEMMER's Avatar
Just the facts...
need a little more application info.
no, it's not like a chebby.
bill
Old Jul 23, 2008 | 09:45 AM
68ragtop's Avatar
7 degrees BTDC on my 68 350.
Old Jul 23, 2008 | 12:11 PM
Oldsguy's Avatar
Past Administrator
20 degrees BTDC on my '76 350. If it is on the engine in the car in your avatar then you could use the recommendation above as a starting point. I bet it even varied from the other 48 to Kalifornia as well. Joe would know for sure but I bet they were already into keeping the world green and preventing smog in '68 over on the left coast. That may have meant a different initial timing for a California car.
Old Jul 23, 2008 | 12:39 PM
olds68's Avatar
I guess it depends on the year of the 350 but 1968-1972 is 8 degrees btdc @ 750 rpm with the vacuum advance plugged. If you still run points, this can be fine adjusted 1 degree for every 1 degree dwell change at the points. 10 degrees should be fine also.
jpc647
Jun 10, 2013 11:48 AM
442scotty
May 13, 2009 05:42 PM
tedster
Jan 1, 2009 05:39 PM
lunatic
Jan 14, 2005 12:02 PM
<Tim>
Jul 17, 2003 05:06 AM
