Help I.D. Motor-if you can
Old Apr 23, 2009 | 04:48 PM
GoodOldsGuyDougie's Avatar
Here is the Engine #'s --395558-2 and the Heads are marked #5 .It's of course a Olds 350 but I'm just trying to make sure this is the original factory motor for this Car and some factory details on it. I have the factory 69 Olds book but it wasan't any help. Here is the I.D. on the Car. #-336879E113548. Thanks for your help and time friends.
http://www.flickr.com/photos/35557405@N08/
Old Apr 23, 2009 | 06:49 PM
ent72olds's Avatar
Registered Luser
I believe you have to look for the # stamped on a pad on the front of the engine, below the head behind the alt(if it is an a/c car I believe...left side!) That # should correspond with the sequence # at the end of your VIN...unless it was a dealer warranty replacement it may be blank(should have been stamped by the mechanics, but often too lazy!)....the experts will chime in!
Old Apr 23, 2009 | 07:03 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
It's a 350.
www.oldsmobilewiki.com
Old Apr 23, 2009 | 07:56 PM
The #5 heads would have been factory installed on a 1969 350.
Old Apr 24, 2009 | 10:57 AM
Thanks Guys,
Joe, thanks that's the info, that's what I needed. I wanted to make sure it was a correct Olds 350 for the 1969 Cutlass.
ent72olds-Thanks for that info, I've been looking all over for the Numbers.It was an original A/C Car so I'll give a new look tonight.
Alex72cutty
18
Jul 30, 2014 08:25 PM
KDAWG97M3
Mar 5, 2014 12:55 PM
scooter123
Jan 6, 2014 05:10 PM
79pont455
Mar 28, 2012 06:37 PM
85greentoro
Jul 4, 2007 02:09 PM
