Can you run a TH400 with a Olds 350 motor?
Old Jul 25, 2014 | 09:38 PM
Alex72cutty's Avatar
I have a TH350 trans and was looking for something with an extra gear. Any advice would be helpful.
Old Jul 25, 2014 | 09:43 PM
coppercutlass's Avatar
Chevy budget Olds powered
The th400 is a 3 speed just like the th350 but it actually takes more power to turn it since it has more mass and heavier hd. components.
Old Jul 25, 2014 | 09:46 PM
Oh, didn't know that. Thanks!
Old Jul 25, 2014 | 10:18 PM
johnnyjaws's Avatar
its a much stronger trans useuly put behind a big block but will bolt right up to a small block ur 350 trans can handle a lot of power.!
Old Jul 25, 2014 | 10:20 PM
johnnyjaws's Avatar
if u want a extra gear put in a 200 r4 they have a over drive in them
Old Jul 25, 2014 | 10:35 PM
Yea, I thought about that too. Seems like I would have to find someone that has good knowledge of the 200r4 due to problems others have talked about.
Old Jul 25, 2014 | 10:37 PM
The th350 has it's weak points anything above 400 hp 450 tops I would start addressing the weak spots. The 200r4 will cost a lot more to handle any power and live.
Old Jul 25, 2014 | 10:43 PM
I just had my engine rebuild and should get around 400-425hp. I've heard that overdrive would be better on the engine that is the reason why I would go with 200r4. What can I do to the Th350 to make it better?
Old Jul 25, 2014 | 11:04 PM
intermediate sprag race is weak and the center support are the 2 things most guys have said to upgrade . You can use the center support from a 700r4 and it will have more strength in that area.
Old Jul 25, 2014 | 11:12 PM
Ok
Old Jul 26, 2014 | 05:32 AM
70cutty's Avatar
Beer Connoisseur
Look into gear vendors overdrive unit. It's not a bad alternative for OD. It bolts up to the th-350. I have not heard anything bad about them.
Old Jul 26, 2014 | 07:24 AM
While this is true, the 200-4R has two advantages over the TH350 (or TH400). The first is the obvious 0.68:1 overdrive fourth. The second is the steeper first gear (2.74:1 vs 2.52:1 in a TH350). Together I think this makes it worth the cost of a properly built 200-4R. As for the GV overdrive, a complete installation will cost at least as much as a built 200-4R, and likely more when you add in the cost of a custom driveshaft, possible floorpan mods, and other required changes. Also, the GV only gives you the overdrive, not the benefit of a steeper first gear for improvements off the line.
Old Jul 26, 2014 | 07:37 AM
The 200r4 does have that advantage of the steeper first gear and overdrive. I personally would do the GV unit simply because its been a proven unit that can handle the power. You build a good th350 or th400 which is bullet proof then add a good od. unit ad you have nothing to worry about. I would probably be a little un easy about the 200r4 since I have read about guys who have built them and they still failed which is the nature of the beast if you drag race and abuse it but the life expectancy of a th400 is much longer so to speak in relatively stock form and the th350 has limited life expectancy with no mods.
Old Jul 28, 2014 | 12:00 PM
Since your in the Dallas area look at Jakes Performance. He has the 2004r figured out. He also builds cusom converters.
Old Jul 28, 2014 | 03:34 PM
jag1886's Avatar
This is the answer all you need is someone that is an expert with this transmission. If you want to know everything there is to know about 2004R go to the Buick Grand National sights, those boys have it figured out.
Old Jul 29, 2014 | 12:36 AM
Will do Thanks!!
Old Jul 29, 2014 | 12:38 AM
Have been on the site for the past couple of days. Thanks
Old Jul 29, 2014 | 03:52 AM
5998DownUnder's Avatar
Tony Lombardi of ROSS RACING ENGINES, Niles Ohio deals with Oldsmobile engines and transmission. He has some quality trans adapters there.
He is a member here.
John
(From Australia).
Old Jul 30, 2014 | 08:25 PM
TexasT's Avatar
You say Dallas, there is a guy that does a lot of Buick guys trans out towards rockwall. Those who have his work seem to like it.
shamusj
Mar 4, 2016 06:48 AM
86odls
Feb 22, 2014 07:26 AM
Olds24
May 8, 2013 04:55 PM
allyolds68
Feb 14, 2012 09:06 AM
59-59-59
Oct 18, 2008 02:37 AM
