Olds 330 ci VS. Chev 350 ci??
I have a 1965 f-85 with what I am pretty sure is a 330. The motor needs to come out for a rebuild. I was wondering if a Chev 350 will drop right in and bolt up to the 2 speed power glide? Just need to get it mobile.
I've been thinking about one of those used Jap engines but I've been thinking Diesel ...
With a turbo and a chip you can produce copious amounts of torque...
If they can motivate a f350 to a 12 sec pass I bet a 3500 lb "compact car" would rocket ...
The Cutlass was considered a "Compact Car" when it was released, thus the hub bub when they put modified truck engines in 'em ...
Jesse,
Like others stated a 350 Olds motor would be an easy swap. Also, you might even be able to find a good 403 as well. (Another easy swap) As Pat mentioned, search the big/small block sites for more info. Good luck on your search.
skryla
October 17th, 2013 07:04 AM
