Carb power hole
Carb power hole
OK, I have a qjet for my 71 Cutlass Supreme. It is working well with two issues. One is the standard bogging and I am not yet concerned about that. The one I am concerned with is a power hole that is erratic and happens regularly but cannot be anticipated. When going down the road under partial throttle (cruising) the engine will lose all power for about a tenth to a quarter of a second and go again. So it is a complete power loss for these small durations. It can happen once ever so often of somewhat regularly. The float appears to be properly adjusted and is letting enough fuel into the accelerator pump but I am now lost. The engine idles and runs smoothly otherwise with the exception of the WOT bogging (I will attack later as I RARELY go WOT) and this issue. I have the Doug Roe Rochester Carbs book which lists this as one of the low float problems but it appears properly adjusted. Thoughts guys?
Not standard bogging, strictly a cutout, there is a difference.
It is not electrical, all of that has been verified. It is fuel delivery. It didn't do it until the carburetor was adjusted this week. Now that it is working so much better this problem popped up. I am going to replace the 2' of old fuel line to the fuel pump in case it is collapsing. Also going to check for any possible vacuum leaks or carb leaks.
X2-MDchanic. I've spent most of 2 summers chasing a failing aftermarket tach that gave a short duration electrical cutout with no rhyme or reason, solved by cutting all 3 wires to the tach. I don't think fuel delivery could cause an intermittent, short duration, "miss".
Sorry, any word I selected for miss would take the topic the wrong way. I think that is what you meant.
HMMMMM thinking about it, new points were just put in at the garage since it was in for other work. It is possible I suppose that they messed something up in the distributor, I will look into that tomorrow. I need to get a timing gun and work on that anyway since I realized today I was using manifold vacuum for the timing advance.
That perfectly describes an electrical problem in the ignition.
If that fixes it, great. In the event that it starts again, replace that wire. Sometimes the wire strands inside the insulation break. This can cause shutting off. Moving the wire, or wiggling it can allow the strands to make better contact and work for a while. Ask me how I know.
