Carb power hole
Old Sep 20, 2014 | 09:24 AM
tonyric's Avatar
Carb power hole
OK, I have a qjet for my 71 Cutlass Supreme. It is working well with two issues. One is the standard bogging and I am not yet concerned about that. The one I am concerned with is a power hole that is erratic and happens regularly but cannot be anticipated. When going down the road under partial throttle (cruising) the engine will lose all power for about a tenth to a quarter of a second and go again. So it is a complete power loss for these small durations. It can happen once ever so often of somewhat regularly. The float appears to be properly adjusted and is letting enough fuel into the accelerator pump but I am now lost. The engine idles and runs smoothly otherwise with the exception of the WOT bogging (I will attack later as I RARELY go WOT) and this issue. I have the Doug Roe Rochester Carbs book which lists this as one of the low float problems but it appears properly adjusted. Thoughts guys?
Old Sep 20, 2014 | 09:46 AM
Sure it's not electrical?
Old Sep 20, 2014 | 10:21 AM
brown7373's Avatar
Ditto Eric. Standard bogging?
Old Sep 20, 2014 | 10:38 AM
Originally Posted by brown7373
Standard bogging?
Wasn't gonna go there...
Old Sep 20, 2014 | 11:42 AM
tonyric's Avatar
Not standard bogging, strictly a cutout, there is a difference. It is not electrical, all of that has been verified. It is fuel delivery. It didn't do it until the carburetor was adjusted this week. Now that it is working so much better this problem popped up. I am going to replace the 2' of old fuel line to the fuel pump in case it is collapsing. Also going to check for any possible vacuum leaks or carb leaks.
Old Sep 20, 2014 | 12:28 PM
CutlassDad's Avatar
X2-MDchanic. I've spent most of 2 summers chasing a failing aftermarket tach that gave a short duration electrical cutout with no rhyme or reason, solved by cutting all 3 wires to the tach. I don't think fuel delivery could cause an intermittent, short duration, "miss".
Sorry, any word I selected for miss would take the topic the wrong way. I think that is what you meant.
Old Sep 20, 2014 | 04:33 PM
tonyric's Avatar
HMMMMM thinking about it, new points were just put in at the garage since it was in for other work. It is possible I suppose that they messed something up in the distributor, I will look into that tomorrow. I need to get a timing gun and work on that anyway since I realized today I was using manifold vacuum for the timing advance.
Old Sep 20, 2014 | 04:38 PM
Consider a bit of insulation rubbed off of the wire inside the distributor occasionally touching ground.
Old Sep 20, 2014 | 05:06 PM
That may not be an issue. Some folks like manifold vacuum, others like ported. Just depends upon which one your engine responds better to.
Old Sep 20, 2014 | 07:31 PM
brown7373's Avatar
That perfectly describes an electrical problem in the ignition.
Old Sep 21, 2014 | 08:01 AM
tonyric's Avatar
Ya, OK so I was wrong. LOL When the points were replaced the coil wire was too close to the side of the distributor and when I moved it the stalling was eliminated.
Old Sep 21, 2014 | 09:39 AM
Octania's Avatar
I have heard that "90% of all carb problems are in the ignition system"
Further evidence.
Old Sep 21, 2014 | 01:09 PM
brown7373's Avatar
If that fixes it, great. In the event that it starts again, replace that wire. Sometimes the wire strands inside the insulation break. This can cause shutting off. Moving the wire, or wiggling it can allow the strands to make better contact and work for a while. Ask me how I know.
Old Sep 21, 2014 | 02:16 PM
Glad you got it fixed.
As mentioned, that wire's either got a break or a bare spot - I'd replace it now, instead of later in the rain on the side of the road.
Old Sep 21, 2014 | 02:37 PM
tonyric's Avatar
It was the blade turned close to the side. I loosened the screw, turned it and problem gone.
TheRuss
Sep 30, 2025 05:33 AM
1970VistaCruiser
Jul 8, 2014 05:49 PM
Tallpaul67
Jun 15, 2014 10:17 AM
RAMBOW
Aug 18, 2012 12:00 PM
silverriff
Dec 4, 2008 01:51 PM
