1965 330 with #2 heads, rocker nuts
We have our families 65 Cutlass drug out of storage and were really enjoying it until this all started.
A rocker arm nut backed off and the rocker begin to clatter. So I pulled the valve cover went to TDC and tightened until I felt resistance while turning the push rod (zero lash) then went 1/4 turn.
It spun loose again a mile down the road. Thinking it had a worn/stretched nut I bought 3/8 Crower sure locks and changed them all in the same matter. Now they all clatter.
They are pedestal mounted and the heads are #2. I keep reading they are non-adjustable but can not find any online reference as to how to actually set them. A post mention 25 ft lbs. but it did not feel right.
Any ideas before sacrificing these covers and just setting lash while running?
Thank you,
Thank you,
Can you post a picture of your setup? The 65 setup is an odd ball because it uses a 3/8 stud vs 5/16 bolts on the 66 and later V8's. I believe they are non adjustable and just torque down as the 66 and up setups. I found this out in another thread while quoting the parts list that mistakenly included the 65's as the same part number as the 66 and later in the post below.
https://classicoldsmobile.com/forums...-question.html
I attempted to torque at 25 ft. lbs. per a reference found on the board here, but got nervous as it felt like I was simply collapsing the lifter.
Do you torque each cylinder at tdc compression stroke with the lifters off the lobe and valves shut?
Thanks for any pointers!
CutlassLegend
September 21st, 2011 02:56 PM
Tom442
July 25th, 2011 02:46 PM
