Is the intake valley baffle needed?
Old Sep 17, 2014 | 11:44 AM
hackmansr's Avatar
OK, I know there are posts regarding this topic, but I have not found the specific answer to the need of the lifter baffle. I am rebuilding my 350, completely, I am ready to install the intake manifold, and I have a new valley pan (turkey tray) gasket. I do not recall removing a baffle under the original turkey tray, but the threaded holes are there.
Is the lifter baffle under the turkey tray required? If so, where can they be obtained.
Old Sep 17, 2014 | 01:13 PM
It is not required. Some engines have it, some don't; same thing for the drilled holes. My engine doesn't have the holes, and obviously doesn't have the baffle, either.
Old Sep 17, 2014 | 02:08 PM
The holes in your SBO valley are an artifact of the 330 motor, which used a baffle and separate intake gaskets. When Olds went to the one-piece turkey tray design, they stopped using the baffle on SBOs.
BBOs for some reason retain the baffle and the turkey tray intake.
Old Sep 17, 2014 | 05:48 PM
hackmansr's Avatar
Baffle
Thank you for the info. I was confused as the Olds service manual shows/refers to it, but there wasn't one when I disassembled it. Now I can proceed!
timholliday
Oct 24, 2014 03:04 PM
69442murph
Jan 12, 2013 12:30 PM
Insom
Oct 16, 2010 07:52 AM
Flye
May 12, 2009 05:30 PM
mcutlass1969
Jul 12, 2007 04:55 AM
