350 heads
350 heads
I have an original 69 350 with terrible heads. I had them checked and I need valves, guides seats and the works. They are 64cc #5. They were shot.
I need some used heads. Can I use a mid 70's 403 or a 350 heads. This will give me hardened seats. I'm going back with flat top pistons and I'm looking for a small cc head for more compression and ability to burn unleaded gas.
Also I'm looking for a hi torque cam that's not too extreme but still gives ma good sound and low torque.
CAN SOMEONE PLEASE HELP ME?
403 heads on a 350 will drop the compression so low the engine would probably run on kerosene. Don't use them. Find a set of 7A or something in that family. Changing the pistons is a good idea to up the compression. Contact Smitty or one of the other good builders for cam recommendations.
Heads
I am in Lewisburg, Tn. How much do you want and what shape are they in?
You may e-mail me at: jimr3@bellsouth.net.
Thanks,
Jim
