350 heads
Old Aug 11, 2014 | 03:29 PM
Jimmy Jo's Avatar
350 heads
I have an original 69 350 with terrible heads. I had them checked and I need valves, guides seats and the works. They are 64cc #5. They were shot.
I need some used heads. Can I use a mid 70's 403 or a 350 heads. This will give me hardened seats. I'm going back with flat top pistons and I'm looking for a small cc head for more compression and ability to burn unleaded gas.
Also I'm looking for a hi torque cam that's not too extreme but still gives ma good sound and low torque.
CAN SOMEONE PLEASE HELP ME?
Old Aug 11, 2014 | 03:42 PM
edzolz's Avatar
403 heads on a 350 will drop the compression so low the engine would probably run on kerosene. Don't use them. Find a set of 7A or something in that family. Changing the pistons is a good idea to up the compression. Contact Smitty or one of the other good builders for cam recommendations.
Old Aug 11, 2014 | 04:30 PM
cutlassefi's Avatar
I can help with the cam when you're ready.
Which "flat top" piston are you using? With a stock 7a head you'll have over 10.0:1 with the true flat top. More info would help. Thanks!
Old Aug 11, 2014 | 05:10 PM
Jimmy Jo's Avatar
Heads
Thank so much for the info. I'll be getting back to you.
Jim
Old Aug 12, 2014 | 08:22 AM
cutlassrichard's Avatar
I have a pair of rebuilt #5 they have hardened exhaust seats, pm if interested
Old Aug 12, 2014 | 05:04 PM
1977 Supreme's Avatar
350 Heads
I may have a set that you are looking for. It looks like you are in the mid TN area as I am just holla at me.
Old Aug 12, 2014 | 05:17 PM
captjim's Avatar
As others have stated, flat top pistons and older 350 heads will get you 10 to 1 Cr. With that much compression, you won't be able to run a mild cam on pump gas. Are you boring and rebuilding with new pistons? If so, which ones? Also, head chamber sizes vary, so you need to measure them (whichever you decide to use) and factor that into the calculations to determine the true CR.
Old Aug 13, 2014 | 06:58 AM
For some reason it wouldnt let me reply to your pm, I'm asking 400 they have new guides, hardened exhaust seats, freeze plugs and 4 new valves
Old Aug 13, 2014 | 06:42 PM
Jimmy Jo's Avatar
Heads
I am in Lewisburg, Tn. How much do you want and what shape are they in?
You may e-mail me at: jimr3@bellsouth.net.
Thanks,
Jim
lunaboy
Sep 24, 2018 10:15 AM
olds4life
Dec 25, 2012 12:56 AM
gearheads78
Nov 10, 2009 09:31 PM
dharlett
Sep 23, 2009 03:30 PM
shaks 442 clone
Oct 18, 2008 09:41 AM
