Edelbrock Carb Vacuum Lines
Old May 14, 2008 | 10:05 AM
#1CutlassSupreme's Avatar
Question Edelbrock Carb Vacuum Lines
So I just got my new Edelbrock Thunder Series 650CFM Carb and my Performer Intake. (Freakin' excited like christmas here!!)
Anyway, on the back side of the carb there is a vac port that can be used for the power brake booster, but there is also a port on the intake manifold just like on the stock 350 Olds intake.
Any suggestions on which one is best to hook into or if there is an advantage one way or the other? More vac on the carb vs. the manifold?
I'm running a bit bigger cam and I'm doing a 4-wheel power disc brake conversion with a new booster and new master cylinder. So what I gather from an earlier post is that I'll need as much vac as I can get (Btw; the car currently has stock front disc brakes.)
Thanks!
Old May 14, 2008 | 02:14 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
I'd run manifold vacuum.
Old May 14, 2008 | 03:02 PM
There's absolutely no difference. They both provide manifold vacuum. Just pick one and cap the other.
Old May 14, 2008 | 04:28 PM
Kinda figured they were bout the same, but wasn't sure if one beling closer to the head had more or less vac than the other.
Thanks again.
alwayssomething
Jan 29, 2010 06:52 PM
StarfireFox62
Sep 25, 2008 01:29 PM
terribleonexx88
Mar 16, 2007 12:00 PM
Chumley
Jan 3, 2007 06:00 AM
bbock
Jun 5, 2006 11:50 AM
