Starting a new 350 build this weekend.
Old Jan 9, 2008 | 06:59 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
I'll keep you guys posted on the progress. Dug out the freebie 350 from the garage and pulled the intake off today. Water ports look pretty corroded. The water neck isn't even re-usable it rotted so much. The bigger problem is that I don't remember who has my motor chains on permanant loan.
At least the hoist is together.
Old Jan 10, 2008 | 11:31 AM
captjim's Avatar
What is the plan, driver or hot-rod? I have a 355 at the shop I work at, bored, honed, align hone checked out OK. Speed pro flat tops and a Voodoo 227/233 cam. Need to get going on the heads.
Old Jan 10, 2008 | 12:42 PM
Redog's Avatar
Is there going to be another 350 Delta on the board?
Old Jan 10, 2008 | 01:05 PM
Yeah, I didn't know what to build, I have so many cores laying around. 3 350s on the floor of the garage right now and a 455 on my stand At the moment. I don't feel like throwing 5 grand at the 455 right now, and it already runs fine with 60,000 Orig. on it. I didn't want to "waste it" on an 80's Delta. Plus I have a spotless th350 w a kit just begging for a new friend.
I'm using the K. I. S. S. method on this one. (keep it simple, stupid)
350ci/th350/350hP/3:08
More specs to come when I'm done playing around on paper.
Let the overtime begin!
Old Jan 10, 2008 | 01:08 PM
I'm using 7A's if anyone cares.
Old Jan 10, 2008 | 02:25 PM
72CUTTY's Avatar
hey j chicago^^ i have a 72 cutlass with a 350.. i want to rebuild it too.. now my question is.. do you think those rebuild kits they sell on ebay are worth it.. i really need help.. sorry for stealing your thread
Old Jan 10, 2008 | 02:52 PM
The_Jeremiah's Avatar
i recommend ordering your rebuild kits from northern auto parts (http://www.northernautoparts.com). Or you can call them. They are in Soiux City, they ship fast, have great parts, and great deals. The master rebuild kit for an olds 350 is like 380 i think. Mine ended up being 655 because of all the extra parts i ordered. but the master kit comes with the piston heads, over sized ones are the same price, along with your bearings, plugs, lifters, cam, timing chain, gaskets, oil pump. And you can add almost anything to your order. On top of that it was only like 20 bucks for shipping for me, and i live in washington. Dont do the ones on ebay, its too much of a hassle, and your not getting a good deal
Old Jan 10, 2008 | 03:42 PM
I would suggest Summit, or Jegs.
Old Jan 10, 2008 | 03:57 PM
captjim's Avatar
Guys, be REALLY careful with your piston choices!!! Most "kits" have stock replacement 22cc dish pistons sitting .040-.050 in the hole, brutalizing any chance at decent compression. Even with older 350 heads, cr ends up at 7.5 to 1, and then over-camming. Ask me how I know!! I have a 355, and after decking .050 off the block, milling the heads down to 60 cc, and using a .039 gasket, I have 9.05 to 1. Intake issues, etc. Get the Speed Pros, and if you need to mill a dish in them to get the CR down to a streetable level. Also, beware the el-cheapo timing chains. If you use them, degree the cam!! Something you should do, anyway. IMO, get the Cloyes, worth the extra $.
Old Jan 10, 2008 | 04:14 PM
72CUTTY's Avatar
^^^ damn i gotta look more into it.... i only understand about 25% of what captjim said.. i guess i have to look for a mechanic so he can tell me what do i buy... i did not want to do that.. i wanted to buy the things and just take them to someone to puttem on for me.. i tought it was just putting new flat top pistons, better camshaft. new rings... but its more than that.. i also read that all that wont make a difference if u have the stock gears ? is this true?? sorry for all the questions..
Old Jan 10, 2008 | 06:24 PM
OH NO!!!!
Don't pawn it!! Sweet sig picture.
No sweat about the thread-jack, It's going to be a few days till I post any progress anyway. Talk away, and hopefully, someone learns something.
Old Jan 10, 2008 | 07:41 PM
88 coupe's Avatar
Junior Member
Originally Posted by 72CUTTY
........ i only understand about 25% of what captjim said ........
Don't feel bad. I know what he's talking about, and I still don't understand most of it.
........ i have to look for a mechanic ........
You will need one, if you cannot remove and reinstall the engine yourself. You will also need an automotive machine shop. If your mechanic can recommend one, all the better.
........ so he can tell me what do i buy ........
It is most practical to have the machine shop get all your parts for you. Notice, I did not say cheapest.
........ it was just putting new flat top pistons, better camshaft. new rings... but its more than that ........
Your engine block, and heads, will have to be machined to make the new parts fit properly. In order for that to happen, the engine must be removed from the car, and completely dismantled. Upside is: when you get it back from the shop, it will be "squeeky clean".
........ all that wont make a difference if u have the stock gears ........
Rear gears are only a part of your combination. The parts you choose, will depend how you will use the car, and the depth of your pockets.
As for captjim's post? Your machine shop will already know what to look out for, and how to do the job properly.
Norm
Old Jan 11, 2008 | 03:58 PM
captjim's Avatar
Don't feel bad. I know what he's talking about, and I still don't understand most of it."
Let me know what you think is inaccurate or what you don't understand, and I'll try and clarify it for you.
Also, NOBODY mentioned working with a builder or a machine shop. The recommendations were Jegs, Summit, and Northern. The pistons that come in those kits are the generic big dish, low comp ones. Norm, you obviously know your sh*t, but why do you feel the need to constantly insult and talk down to people? I don't get it. There are plenty of guys on here who post good practical info without being condescending, patronizing, and rude. You are just not one of them. You go out of your way to be rude and obnoxious, when it is just as easy to be polite.
Old Jan 11, 2008 | 10:27 PM
88 coupe's Avatar
Junior Member
Don't feel bad. I know what he's talking about, and I still don't understand most of it. ........
Let me know what you think is inaccurate or what you don't understand, and I'll try and clarify it for you ........
You are a bit late. I already explained it to him.
........ nobody mentioned working with a builder or a machine shop ........
Are these engines going to rebuild themselves?
........ The recommendations were Jegs, Summit, and Northern .........
Only those three? Read the following, again:
........ my question is.. do you think those rebuild kits they sell on ebay are worth it ........
Wasn't ebay being discussed?
........ you obviously know your sh*t .......
As I have already explained, several times, it is only an illusion.
........ why do you feel the need to constantly insult and talk down to people? ........
Why do you feel the need to make vague accusations?
........ I don't get it .........
That is obvious. Maybe you should read my post again. This time, read what is actually in it.
........ There are plenty of guys on here who post good practical info without being condescending, patronizing, and rude ........
And there are plenty of guys, on here, who discuss that practical information, without resorting to insults/name calling/flaming.
........ You are just not one of them ........
Thank you, for confirming that.
........ You go out of your way to be rude and obnoxious, when it is just as easy to be polite.
If you can find an example. Code the quote properly. Then post it, in a PM, along with your objection.
Norm
Old Jan 12, 2008 | 05:47 AM
I thought the kits at Summit seemed like a pretty good deal. Do you have bad experience with them? I notice now that all of the kits contain "dish" pistonss; however, they are forged. It also says that they give you about 9.6:1 compression with an 80 cc head.
http://store.summitracing.com/partde...1&autoview=sku
Does anyone have any other suggestions for rebuild kit suppliers?
Old Jan 12, 2008 | 09:11 PM
88 coupe's Avatar
Junior Member
Originally Posted by Olds64
I thought the kits at Summit seemed like a pretty good deal ........
It is a “generic” kit, that will work fine for a “generic” rebuild, and that is good enough for most people. Whether it is worth the price, might be debatable.
........ all of the kits contain "dish" pistons ........
Why not? It's what Olds used. And what I used.
But, since mine are 3900 lb, 11.9 @ 114/116, 91 octane, drive anywhere, cruisers, what I used would be a different topic.
........ It also says that they give you about 9.6:1 compression with an 80 cc head ........
Using the numbers from TRW-L2323F30, .025" piston top to deck, .040” (compressed) for Fel-Pro Permatorque head gaskets, 0.0" above the top ring, and an 80cc chamber, I came up with 9.33:1
But, I am not a mathematician.
........ Does anyone have any other suggestions for rebuild kit suppliers?
Any machine shop should be able to put together a custom kit that will meet ones individual needs, using parts of equal quality, for the same, if not less, money.
Norm
Old Jan 13, 2008 | 03:42 PM
88 coupe's Avatar
Junior Member
Originally Posted by 88 Coupe
........ But, I am not a mathematician ........
That is obvious. Better go back to math class, Mr Know-it-all. Cr with an 80 cc head, 6cc dish, 4.125 x .040 gasket, and pistons down .025 is 8.3 to 1, not 9.3 to 1. Oh well, it is only one number, no biggie.
You would be more credible, if you used the same numbers as everyone else. They are:
      Using your numbers, I came up with:
        But, since I am not a mathematician, you are probably right.
        Norm
        Old Jan 13, 2008 | 03:46 PM
        captjim's Avatar
        I deleted that when I realized that the thread had somehow gone from discussing 350s to discussing 455s. The 350 Speed pro dish is 6cc. My bad.
        Old Jan 13, 2008 | 05:53 PM
        Motor got a teardown today. This motor was a freebie so I was worried about how rotten it really was. There was almost as much water in the pan as there was oil, and the valley pan had a 1/2'' of carbon in it. Thankfully though it turned out to be a decent core. Hardly a ridge in the cylinder walls, and no bearing scores at all. The only unorigional gaskets on it were the water pump and valve covers.
        Does anyone want a freebie cast iron intake? Makes a great boat anchor for your next fishing trip.
        Old Feb 25, 2008 | 06:46 PM
        the 7a Heads are almost done.
        4 angle jobber
        no porting
        207 intake valves
        162 exhaust
        radiused exhaust seats
        30degree intakes instead of stock 45
        Old Feb 25, 2008 | 06:53 PM
        Norm
        Lmao.
        Old Feb 25, 2008 | 09:02 PM
        LOL you guys are great. and best of luck to you J. I just got my engine done using the northern kit, i might have the "big dish" pistons you guys speak of, but it runs like a top. and i think i got my moneys worth out of it lol.
        Old Feb 26, 2008 | 05:16 AM
        Oldsguy's Avatar
        Past Administrator
        J, if you really don't have anything for the 455 I live close enough to make a road trip to the windy city for the right price. I have room in my garage, or I'll make room.
        Old Feb 26, 2008 | 12:55 PM
        Oldsguy,
        I am intrigued by your offer, I'd hate to let it go because I have been saving it for a nice 77 442 build for a few years now BUT..... anything is possible and my car fund IS getting low.
        Unfortunately, I haven't found a 77 worth a nickel in the area, and my odds of hitting the lotto this month are slim.
        She was a runner, with about 75,000 on her. Just turned it over a few times with a breaker bar yesterday. It is a 72 with complete TCS setup. I also have a 71 Th350 trans with about 20,000 miles on it with the TCS solenoid setup as well. I have had 3 offers on it within the last 4 months without even putting it up for sale, but have held out. I am going to see if Rocket Racing is willing to trade some heads and head work for it, but they are probably up to their ears in cores already.
        I'll let you know what happens if you really are interested. You could probably sell the TCS for 100 bucks on Ebay. 71-72 stuff is ridiculously popular at the moment.
        Ga heads I think it has. No J garb.
        PM me an offer if you like, and I will weigh my options.
        Old Mar 5, 2008 | 02:07 AM
        Here's some flow numbers on the 7a heads after the machine work was performed.
        Int. Ex.
        .100 80 66
        .200 145 109
        .300 185 147
        .400 207 170
        .500 209 180
        1970cutlasssupreme
        Oct 4, 2013 10:29 AM
        62starfireproject
        Feb 15, 2013 03:52 PM
        bccsrc
        Nov 29, 2011 11:08 PM
        Tony72Cutlass'S'
        May 19, 2011 01:25 PM
        1973_442
        Jun 13, 2007 09:22 AM
