The car is an 88 cutlass
The car is an 88 cutlass. We put the engine back together (heads, headers, intake, valve covers, carb). Now it wont start. The spark plugs ARE sparking. We sprayed starting fluid into the carb and it still wont start. I'm troubleshooting. We are 19 years old and poor. Any help will be rewarded with good karma and a lifetime of en-debt-ed-ness from yours truely.
If you have a good strong spark , but it won't fire on starting fluid, the ignition timing may be off , or you may have incorrect spark plug wire connections as Texasred advises. With number one piston at Top Dead Center , on the compression stroke, be sure the distributor rotor is pointing at the number one spark plug wire terminal. ( Put your finger over the spark plug hole to see if the piston is on the compression stroke and is forcing air past your finger, or on the exhaust stroke and not compressing the cylinder contents. )
If the ignition all checks out and it still won't fire, you might double check the cam gear positioning with respect to the crankshaft. (I know, that means taking something apart again !) Good luck !
2blu442
Dec 9, 2020 09:51 AM
Dan Wirth
May 21, 2012 11:30 AM
firefighter5174
Nov 23, 2011 10:47 AM
