interchange engine for 324 w/ standard belhousing
Old Jan 22, 2015 | 10:37 AM
scharpp's Avatar
Scharpp
Is there another engine that will bolt to my standard belhousing on my 55 olds with 324, no luck finding running 324 and whooa engine kit is over $1000
Old Jan 22, 2015 | 12:52 PM
Charlie Jones's Avatar
Phantom Phixer
The good news;
All 49 thru 64 Olds engines will bolt up to your bellhousing.
The bad news;
57 thru 64 engines require an "offset balanced flywheel" which means your flywheel won't work. Plus, all engines from automatic trans cars will have to have the crank drilled for a pilot bearing by a machine shop, after the crank is removed from the engine.
Considering all this , $1000 for an engine kit is not too bad.
Old Jan 23, 2015 | 08:57 AM
Tedd Thompson's Avatar
The good news;
The bad news;
I agree with everything except having to drill the crank but there are many other things that must be changed to make this conversion. I could be wrong on this but as I remember when a friend did a conversion from a 324 to a 394 the crank was already drilled and excepted the slant pan pilot bearing.I don't think the 394 was a stick car they were very rare even back then. Check this link out it list many of the steps that are needed to complete this swap correctly...Tedd......I can't get this link to work but if you use a yahoo search on how to convert a 324 to a 394 engine the first listing pretty much goes through what is needed to swap engines. I wondering if my buddy used a 394 out of a 62 or earlier engine and if there is a difference there?
Old Jan 23, 2015 | 09:25 AM
Phantom Phixer
I think you are wrong Ted.
Check out NAS Backyard's thread.
https://classicoldsmobile.com/forums...unkyard-9.html
Old Jan 23, 2015 | 09:42 AM
http://webpages.charter.net/dhomstad...me1Source1.htm
Got it to work...Tedd
Old Jan 23, 2015 | 09:48 AM
scharpp's Avatar
Scharpp
My 55 Olds is a 3 speed manual factory car, maybe I need to check the block to make sure its a 324? Thought that was all they came with in 55
Old Jan 23, 2015 | 09:51 AM
scharpp's Avatar
Scharpp
hanging to a 394 sounds like a headache waiting to happen, I can do all the work my self, guess I just have to cough up the cash Thanks
Old Jan 23, 2015 | 12:47 PM
scharpp's Avatar
Scharpp
I found a 56 324 runner with dual 4s on it yay!!!
Old Jan 25, 2015 | 03:23 PM
okie88's Avatar
Most 303's and 324's are already drilled and come equipped with a pilot bearing and retainer. Starting in 1957 with the 371's and 394's just standard cars were equipped with them.
Old Jan 25, 2015 | 04:20 PM
Doesn't the Jetaway have a pilot bearing cutout like the slant pan?I always thought it did , could be wrong on this ...Tedd
Old Mar 27, 2015 | 08:33 AM
fuxl's Avatar
This shows the difference between manual (left) and Jetaway (right). From the 1956 factory manual.
Shot Gun Rich
Apr 25, 2014 09:36 AM
wildwillie1981
Jan 17, 2010 04:42 PM
sanemb
May 30, 2008 07:48 AM
Olds Nut
May 28, 2008 06:27 PM
ozoneblue
Drivetrain/Differentials
Aug 23, 2007 03:31 PM
