Help 324 1955 Oldsmobile Engine
Old May 29th, 2008, 02:23 PM
sanemb's Avatar
Question Help 324 1955 Oldsmobile Engine
Hey, if anyone can help, it would be much appreciated. We're putting out 324 engine back together, after getting it machined. We had most of it together and found a alien head set screw with a hole, in the box. A guy that works on engines told us it had to go behind the timing chain cover, that it squirted oil onto the timing chain and gears. After taking the cover off, we found that there is 2 things already there, that look just like this, but are a little bigger. Does anyone know if there is anyplace on the 324 engine that this could go? Or did it just get thrown in the box, when we sent the stuff out to get cleaned?
Thanks,
Sandy
sanemb is offline
Old May 29th, 2008, 10:02 PM
59-59-59's Avatar
Check out the back of the block where there is a freeze out plug in back of the camshaft. My 394 had 2 plugs with the allen head on either side of the freeze out plug. Or check out your manual, in which i have to assume you are using for this rebuild
59-59-59 is offline
Old May 30th, 2008, 04:55 AM
Past Administrator
Oldsguy's Avatar
Sandy, I think you ended up with an extra, that is all. Welcome to our site.
Oldsguy is offline
Old May 30th, 2008, 07:48 AM
sanemb's Avatar
We checked that out last night, and it definitely doesn't go there, so we're really thinking it doesn't go with our engine.
Thanks,
Sandy
sanemb is offline
alexe889
September 23rd, 2010 11:39 PM
rfaller
July 31st, 2008 09:23 PM
Olds Nut
May 28th, 2008 06:27 PM
dendav
March 30th, 2008 06:41 PM
rfaller
February 24th, 2008 01:13 PM
Quick Reply: Help 324 1955 Oldsmobile Engine
