Carburetor Help
Old May 17, 2016 | 08:30 AM
Lpinchard350's Avatar
Carburetor Help
Looking for help choosing a new carburetor. I have a 1968 cutlass with the following:
-1972 350 motor
-Gasket match stock heads
-Heavy duty valve springs
-Edelbrock performer intake
-Comp cam with the following specs:
Cam Style: Hydraulic flat tappet
Basic Operating RPM Range: 1,200-5,600
Intake Duration at 050 inch Lift: 218
Exhaust Duration at 050 inch Lift: 224
Duration at 050 inch Lift: 218 int./224 exh.
Advertised Intake Duration: 262
Advertised Exhaust Duration: 274
Advertised Duration: 262 int./274 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.475 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.480 in.
Valve Lift with Factory Rocker Arm Ratio: 0.475 int./0.480 exh.
Lobe Separation (degrees): 110
-Flowtech headers
-Th350 with shift kit and 3500 stall converter
-3:91 gears
-2 1/2in exhaust with flowmaster mufflers
-28in tires
Intended use is a cruiser and playing around on the street.
What suggestions do you guys have for a good carburetor?
Old May 17, 2016 | 10:31 AM
bccan's Avatar
My .02 - Lightly modded Qjet.
sparkyscarbs.com 414-447-7500
deanoscarbs.com 870-830-5470
everyday-performance.com 860-218-5780
Old May 17, 2016 | 01:02 PM
I second the QJet.
Originally Posted by Lpinchard350
-1972 350 motor
Does this mean factory 8.5:1 compression? Or was the engine rebuilt with smaller dish pistons?
Old May 17, 2016 | 01:11 PM
Factory compression
Old May 18, 2016 | 05:36 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Either the stock Qjet or 76-up Qjet custom tuned for your application. Everyday Performance does a good job and is affordable. If you provide the core and skip the plating, custom tune with bushing work was around $250 for me. It ended up about $100 cheaper than the Street Demon carb. The 625 cfm Street Demon is another option, based off the Carter Thermoquad with many improvements in an all new 3 barrel castings. There is Aerospace polymer or aluminum body options, black ceramic coating, full tuning kits and even a tps available to run an electronic trans.
Old May 18, 2016 | 05:41 AM
cutlassefi's Avatar
Quick Fuel Slayer 750. Electric choke and way easier to tune than a Qjet.
Jmo.
Old May 18, 2016 | 05:53 AM
brown7373's Avatar
Can't go wrong with a properly functioning Q-jet. Did the cam call for heavy duty springs? They don't do much for a cam that doesn't require them, except extra wear on the components.
Old May 18, 2016 | 07:34 AM
Yes, the cam called for the HD springs. All came together as a kit.
Old May 18, 2016 | 07:49 PM
1BOSS83's Avatar
Jmo.
Agreed.
matchek
Aug 14, 2012 11:18 AM
Al2011
Aug 16, 2011 08:03 AM
middlebrookgt
Feb 26, 2011 04:53 AM
yeahbuddy
Jun 1, 2010 05:38 AM
ViceGuy
Mar 25, 2007 01:43 PM
