distributor bolt hole question - 350
Old Jul 5, 2016 | 06:45 PM
oldss72's Avatar
Hello,
I need to replace my intake manifold gasket on my 72 cutlass with a 350.
When I went to remove the distributor, the hold down bolt snapped off flush with the block. I can drill it out and tap it - I just want to know if this is a blind hole or if it is a through hole. It looks like a through hole to the flywheel but I cannot tell from Images I have been able to find - if someone could look on a spare engine or knows from experience it would be a great help. Also - If I need to tap a larger hole is there any issue going slightly larger or is there not enough meat (say for a helicoil).
Thanks!
Old Jul 6, 2016 | 06:18 AM
Run to Rund's Avatar
It is a through-hole into the flywheel area. You could go bigger or heli-coil it.
Old Jul 6, 2016 | 06:47 AM
oldss72's Avatar
Thanks! I appreciate it
Old Jul 6, 2016 | 07:01 AM
My442's Avatar
Weld a nut to it - it will come right out.
When you put in the new bolt, use Anti Seeze.
Wood
Nov 15, 2015 03:56 PM
RAMBOW
Aug 18, 2012 12:00 PM
oldzy
Jun 26, 2011 05:08 PM
stlbluesbrother
Feb 25, 2011 09:27 PM
silverriff
Dec 4, 2008 01:51 PM
