I need a new fuel tank sender for my 70 Cutlass S, return or not?
Old Aug 24, 2016 | 02:03 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
They are the same price, I currently have the no return line sender that doesn't register, being non A/C. I have a return line pump on the 350 but also have a new chrome non return line pump as well as one on the 260. Thoughts? It will see some track time and will eventually have A/C and EFI but I assume a new sender will be needed at that point.
Old Aug 26, 2016 | 05:44 AM
distributorguy's Avatar
You can always cap the return line if you don't use it. You can't just add a return line for EFI without it. Easy choice.
Old Aug 26, 2016 | 02:50 PM
+1.
And adding a return line will eliminate the (unlikely) chance of vapor lock in hot, stop and go traffic.
Old Aug 27, 2016 | 04:53 AM
Thanks guys, another example of GM not adding a return line for no reason. My 88 CSC has one, supposedly the sbc 305 G body cars up here did not have a return line. My 81 Delta 88 had the line capped I believe, not sure if it was a factory thing or not, we had weird options up here. It was a non CCC car with no air pump, factory plugs in the heads. I think that was part of the reason it was so dam reliable. That and a huge stack of bills from new, mostly very regular oil changes and other important maintenance.
Old Aug 29, 2016 | 04:50 AM
For no reason? Return lines are necessary with some emissions systems and virtually all fuel injection systems. The factory would not run a line in a car that doesn't need it, unless other models of the same body style require them.
Old Aug 29, 2016 | 06:41 AM
I meant GM didn't spend dollars for no reason. I am thinking because our emissions laws were so relaxed up here. I am almost positive it was capped, unless it had a charcoal canister, pretty sure it didn't. We didn't get air pumps till 83 and no CCC till 86 I believe with the exception of the Hurst/Olds and 442. They were basically US cars with Km/hr Speedo's. Other than the big cars and performance cars, all were sbc's from the early 80's for sure. Pontiac's with exception of a few models were like that from the 60's up here.
olds 307 and 403
Aug 25, 2016 07:26 AM
1964super88
May 31, 2014 08:50 PM
davepnola
Dec 2, 2010 09:00 PM
dhoff
Jun 8, 2009 03:49 AM
68conv455
May 20, 2008 02:03 PM
