What type of intake manifold gasket?
Old Jul 23, 2016 | 07:55 AM
Oldssupreme's Avatar
Chris
Hi! I haven't removed the intake manifold ony 72 350 yet but I am taking a trip this weekend to get the gasket. Can anyone tell me what type of intake gasket I need? I have seen a smallish set and another that looks like a larger one piece set. Am i able to use either one or whatever the car came with? Thanks!
Old Jul 23, 2016 | 08:44 AM
The smaller set (4 piece) is used if you have a drip tray at the bottom of the lifter galley. The large pan (turkey tray) is used if you do not have the tray. You do not have the tray.
Old Jul 23, 2016 | 10:14 AM
Chris
Eric, OK, so if I replace it I would need the large turkey pan gasket. Also, Since the only reason I'd be removing the intake is to clean it really well and to replace the gasket- Is there any real need to remove the intake and replace the gasket? Is it a metal gasket? Do these gaskets normally go bad? Just don't want to remove the intake just to replace a gasket if there is a chance that a new gasket wouldn't be as good... Thoughts?
Thanks!
Chris
Old Jul 23, 2016 | 10:32 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Make sure to get the one for the early heads, the 73 and later had a larger center exhaust crossover port.
Old Jul 23, 2016 | 10:39 AM
They last just fine especially with an iron intake. It is a good idea to remove any sludge that accumulates under it. It needs RTV around the water ports and where the rubber seals meet the metal gasket. Or just use good tall beads of RTV in place of the end seals. Be aware if you are replacing head gaskets, your compression will be .25 lower due to thicker head gaskets.
Old Jul 23, 2016 | 10:57 AM
If the engine is running well, with no indication of an intake gasket leak, and all you want to do is clean the intake for cosmetic reasons, I wold not remove the intake.
Old Jul 23, 2016 | 11:07 AM
If the are under the valve covers is free from sludge then in most cases the area under the intake is also. As Kenneth stated above, no need to remove the intake to clean and paint if there are no vacuum leaks and the front and rear seals are fine. Just clean and paint.
There is no difference in quality between the one installed currently and the new ones that are available today.
Old Jul 23, 2016 | 02:53 PM
Chris
Ok thank you. You guys mentioned that if under the valve covers is free of sludge then i should be clean enough to leave the intake on. Could I send a photo of under my valve covers and let me know what you think? To me it looked pretty clean. I can still see the paint marks on the springs and they are original.
Chris
Old Jul 23, 2016 | 03:01 PM
Just post pics on here.
Old Jul 25, 2016 | 08:13 AM
Chris
Olds cutlass heres some pics of the tops of the heads under the valve covers. What are your thoughts about whether or not i need to remove the intake to change the gasket?
Thanks!
Chris.
Old Jul 25, 2016 | 08:14 AM
Chris
And another
Old Jul 25, 2016 | 08:15 AM
Chris
Heres another
Old Jul 25, 2016 | 08:17 AM
Chris
Last one
Old Jul 25, 2016 | 08:42 AM
Looks very clean. Has that engine not run in a while?
Old Jul 25, 2016 | 08:48 AM
If it ain't broke, don't fix it.
Old Jul 25, 2016 | 08:58 AM
Chris
The engine hasnt run since probably 2012 when i started taking the car apart. Ran well then. One thing i am concernd about though is that one side looks a littl cleaner than the other, should i be concerned?
Old Jul 25, 2016 | 09:03 AM
Of the rocker arms? No.
Old Jul 25, 2016 | 09:16 AM
Chris
I mean the head with the pcv valve looks dirtier. Could the valve have been bad? The head with the breather looks clean.
Old Jul 25, 2016 | 09:17 AM
No concern there. That is normal as one side has fresh air coming in from the outside, the other side has all the engine blowby going across it then through the PCV valve.
Old Jul 25, 2016 | 09:22 AM
Chris
No sludge, just carbon deposits
Old Jul 25, 2016 | 09:23 AM
Chris
Ok, thanks Fun71! I shouldn't speak too soon, but this is going pretty well so far, especially with all your guys help!
Chris
Old Jul 25, 2016 | 09:34 AM
Chris
Now you did it....
Old Jul 25, 2016 | 09:41 AM
Chris
Lol! (Other Eric), I have a theory that if i don't say it out loud then it wont work against me! So unless you read my post out loud im okay lol.
Chris
Old Jul 25, 2016 | 09:47 AM
Ruh roooo
86GutlessCutlass
May 30, 2016 08:58 AM
matchek
Mar 19, 2015 03:25 PM
aussiemobile
Feb 15, 2013 07:31 AM
stockwell
Feb 23, 2010 06:23 PM
Olds64
Jan 1, 2009 11:40 AM
