Tick tick tick
Knock knock
85 delta 88
307
There is aticking sound coming from the engine. Sound like it's one the driver side of the engine. When it warms up, the ticking gets quiet. It doesn't go away completely. Anyone know what the problem could be? Thanks!
And I think I might have a knock?!?! Not sure if I'm just paranoid or if I'm really hearing a knock!
307
I agree with 442harv, if you can feel around the exhaust manifold quickly after start up from cold.
The knock could be a bad motor mount or trans mount.
I would check the oil, do an oil change and see if its clean.
Eric
Eric
._.
85 delta 88
307
So here we go. This is my car and the knocking sound. What does it sound like to you guys?!
https://www.youtube.com/watch?v=axk4...ature=youtu.be
307
The speed of the knocking sound increases when I accelerate and decreases when I decelerate. And when I put it in park, at idle it speeds up.
Oh and the brand is pennzoil. IF YOU RECOMMEND A DIFFERENT WEIGHT AND BRAND PLEEEEEAAAAAASE TELL ME. I stood in auto zone looking a oil for 30 minutes trying to pick smh. And that's what I ended up with.
That would make some since. The transmission was rebuilt 2 months ago and I swear I don't remember this knocking BEFORE that. I'm still under warranty so I think I will take it up there Monday and see if they will tighten it down. And hope that fixes the knock.
I'd pickup a cheap mechanical oil pressure gauge and hook it up and see what it is cold and hot.
Ahhhhh yes I can! I will go have the people that rebuilt my trans to look. Thanks man! And everyone. I LOVE THIS FORUM!. Hopefully that's my problem
Check the transmission yourself, or have someone else do it.
Im a plumber, people think plumbers rip people off....how about transmission places, im better at transmissions than 4 trans. shops here.
Also, an engine knock will get louder with time, how many miles since the trans.
See if your egr valve is bad. You can check by removing the egr valve and compressing it by hand so that you hear air and cover the small hole that's on the part the hose goes over and if the valve doesn't stay compressed then it's most likely bad.
That's if you didn't know that already!
The new egr valve helped my knock!
#31
