'70 rocket 350 engine noise
Hi Folks,
I just picked up what looks to be a pretty darn original '70 cutlass supreme in great shape. The motor may have had work done but I can't tell. It's got 70,000 miles on the clock so I'd like to think it's all original. A previous owner did install a HEI distributor and paint the engine block - which makes me believe the motor may have been pulled. The paint looks like parts store gold but it looks to be done well (as in they removed brackets. etc...).
Long story short here.... when the engine is cold I get a strange air-horn like noise at a particular RPM. I don't have a tach and haven't put one on the car yet but I'd say it happens around 1500 to 2000 and goes away.
My first thought was belt but it's not a belt squeal. It sounds more like it could be a bad bushing... I don't see any water leaks but could be anything on the accessory .
The noise is best described as a quiet air horn. It doesn't come on full blast but quickly increases in volume the way an air horn would (as opposed to an electric horn) .
Belts look good and I've looked but the noise seems to scatter around so pin-pointing it is difficult. Just thought I'd see if anyone has experienced anything similar in their travels.
Thanks,
Thanks,
This will sound weird but some early to mid 90s Fords had a similar noise coming from the heater core. The fix was a orfice fitting we would splice into one of the heater hoses. Just pinch off one of the heater hoses to eliminate this as a possibility. The problem was in the heater core but the cheaper fix for the factory was the orfice. Just throwing it out there.
I think this is a definitely a possibility. The factory used a restriction in the inlet heater hose to reduce pressure/flow through the heater core. AC cars have a vacuum controlled valve and non-AC cars have a hose nipple, and both styles have a small hole (1/4" maybe) in the threaded base portion as a restriction. If you don't have that restriction the heater core can moan as the water flows through it.
I'll dig a little more when I have a moment to. Although it's not getting put away for the winter just yet I would like heat and for that noise to be diagnosed.
Thanks for the input!!!
Piece of vacuum hose is the cheapest stethoscopes available.... put one end in your ear and listen around... it works !!
