1972 delta 88 350 possible cam
Old Oct 25, 2016 | 08:16 PM
72delta88's Avatar
I'm trying to figure out if my 1972 delta 88 350 has an aftermarket cam it has a mildly lopey idle and its noticeable even with stock exhaust if the cam may be stock it might be about time for a timing chain since I'm unsure about the cam or chain it has 105k on it
Old Oct 26, 2016 | 03:02 AM
When you open it up to change the timing set, you'll be able to see whether the cam has the factory chamfers on the end.
Old Oct 26, 2016 | 09:12 AM
72delta88's Avatar
the only reason I think its been changed is it pulls hard through 6500 how hard is the chain to do in the car
Old Oct 26, 2016 | 12:47 PM
I would not run the engine up that high if I was unsure of the integrity of the timing chain.
Old Oct 26, 2016 | 06:00 PM
If it will rev to 6,500 RPM, the cam has been replaced.
Are you sure your tachometer is accurate?
It's not the timing chain that you need to worry about (though they do stretch), it's the cam sprocket, whose nylon teeth disintegrate, creating slop and the possibility of the chain jumping a tooth, which would probably be the end of that engine at 6,500 RPM.
No harder to change than any other: pull front accessories, pull water pump, pull damper, remove cover.
Old Oct 29, 2016 | 05:22 PM
Cutlass Fan's Avatar
Is this with the Holley carb on the 2 bll manifold with the adapter? If it is I would doubt that it would "pull hard to 6500" as I doubt any 2 b manifold would flow enough to support that kind of rpm.
Old Oct 29, 2016 | 05:26 PM
72delta88's Avatar
amazingly yes it is I would have to agree it shouldn't pull that hard on that intake
Old Oct 29, 2016 | 05:29 PM
Ha ha. Good point. I hadn't connected the two threads.
Back to my question about the tach.
Thanks!
Old Oct 29, 2016 | 05:31 PM
72delta88's Avatar
ita accurate and we got the problem fixed now ive gotta move the plug wires and redo the timing
Thanks!
Old Oct 29, 2016 | 06:09 PM
I think your tach is VERY optimistic lol.
Old Oct 29, 2016 | 06:29 PM
72delta88's Avatar
I'm goin to get a timing light with a digital read out later I think my bosch tach an my msd box aren't liking eachother
Old Oct 29, 2016 | 06:40 PM
76olds's Avatar
Hookers under Hood
When I read your other post you mentioned backfiring up through the carb. I was thinking a wiped cam lobe at the time but didn't post, but you said the cam was swapped out. I'm surprised to hear that now it could be the chain. Too many threads going here, unless I'm the only one getting mixed up between threads and the supplied information.
Eric
Old Oct 29, 2016 | 06:44 PM
76olds's Avatar
Hookers under Hood
Why would you want to run it up to 6500 rpm, holy jumpin' its a delta 88. You using rocket fuel in that beast.
Eric
Old Oct 29, 2016 | 07:02 PM
72delta88's Avatar
tachs reading way high
Old Oct 29, 2016 | 07:04 PM
72delta88's Avatar
got it fixed the tach was reading way high the msd box doesn't like the tach
I got the timing fixed its dead on the dizzy got loose and turned on me
Old Oct 29, 2016 | 07:20 PM
Really?
How high was it revving when you thought it was revving 6,500?
How does this affect the answer to the initial question you posed here, ie: Do you have an aftermarket cam?
Old Oct 29, 2016 | 07:22 PM
72delta88's Avatar
Really?
my rev limiter kicks in at 4800
Old Oct 29, 2016 | 07:27 PM
Much more realistic.
Thanks!
Old Oct 29, 2016 | 07:33 PM
72delta88's Avatar
Thanks!
I just went out an checked the msd box limiter my neighbor looked at me like I was nuts
Old Oct 29, 2016 | 07:36 PM
76olds's Avatar
Hookers under Hood
Does your neighbour like nuts ? Maybe he's got the munchies haha.
Old Oct 29, 2016 | 07:40 PM
72delta88's Avatar
haha he a d..k so I wont be surprised to get the cops called for the 88 backfiring
Old Oct 29, 2016 | 08:06 PM
76olds's Avatar
Hookers under Hood
Don't give up on your Olds, the guys here are always willing to help give you the information needed to get your Olds running. Get a few tools together that will help you trouble shoot the things that others post.
You'll have it running good in no time. Its good to see young guys like yourself driving Oldsmobiles!!
Put-er-ther you'll learn alot here, just be patient and learn as you go.
Cheers
Eric
Old Oct 29, 2016 | 08:08 PM
72delta88's Avatar
Cheers
Eric
I got it adjusted to 8 degrees initial and I think 26 advance its running great I may swap to a 403 though
Old Oct 31, 2016 | 06:36 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
I would advance it another 2 to 4 degrees, low compression Olds V8's love a lot of timing. Also get a Performer or RPM intake in place of that ridiculous adapter. A 403 with your current 350 heads and an upgraded cam would be night and day.
Old Oct 31, 2016 | 08:44 AM
72delta88's Avatar
that's exactly what I'm thinking the owners holding the 403 for me so I can pick it up in December its 200 well spent
72delta88
Oct 25, 2020 12:01 PM
Dead Reckon
Mar 17, 2014 03:30 PM
Uncle Hulka
Mar 12, 2014 03:41 PM
Dru
Dec 20, 2010 06:17 AM
bigdaddypapenburg
Dec 2, 2009 09:22 AM
