350 rocket back fire at w.o.t
Old Oct 27, 2016 | 08:32 AM
72delta88's Avatar
my 350 rocket is stock except the cam msd system and carb and it runs fine until I give it full throttle from a stop or from around 30 mph I know my exhaust choke block off has a leak can that cause it I drove it at w.o.t on the interstate before the leak started now at w.o.t it back fires and tries to die
carb is a holley 4150 600 cfm d.p
Old Oct 27, 2016 | 09:28 AM
farmer52's Avatar
Sticky valve?
Old Oct 27, 2016 | 09:53 AM
72delta88's Avatar
[QUOTE=farmer52;963736]Sticky valve?[/QUOTEi
the carb is a bit to big and I had it set to lean I cured the rolling w.o.t I'm still trying to figure out the off idle stumble and backfire
Old Oct 27, 2016 | 10:17 AM
All the stuff I have read about double pumpers said you need a high stall or manual transmission since the secondaries open immediately and the engine can't use the available air/fuel at low RPM.
Old Oct 27, 2016 | 10:19 AM
72delta88's Avatar
its 'supposed' to be a vacuum 2nd according to summit racing
the stock worn out 500 cfm 2 barrel Rochester would boil the hides the 600 4 barrel wont it stumbles
Old Oct 27, 2016 | 01:53 PM
80 Rocket's Avatar
You can look at the carb to find out what it is. If it has two accelerator pumps, it is a double pumper.
Old Oct 27, 2016 | 02:00 PM
72delta88's Avatar
it got 1 so its just a dual feed I got most of the hesitation fixed carb was to lean itll chirp the tires now but it still gets smoked by the ols 2 barrel it still pops out the carb when I hit it to full throttle when cold but the exhaust choke block off is leaking air so I can get it tuned in
Old Oct 27, 2016 | 04:42 PM
I was going by your first post where you said it was a double pumper:
Old Oct 27, 2016 | 04:48 PM
72delta88's Avatar
my mistake its a dual feed vac secondary
Old Oct 27, 2016 | 10:42 PM
Back in the 80s I had a Holley 600 and I had to install a secondary vacuum diaphragm spring kit to tailor the opening rate so it would launch properly.
Old Oct 28, 2016 | 10:31 AM
cutlassjoe's Avatar
If it ran good with the 2bbl and not so good with the 4bbl....why not put the 2bbl back on?
Old Oct 28, 2016 | 11:33 AM
72delta88's Avatar
the 2barrel was dumping gas and the body was warped and the local parts store couldn't get a 2 barrel for 2 weeks and it was 50$ more then the 289 I spent on the 4 barrel I'm changine to a 4 barrel intake in January when I sprayed either at the carb base the only leak was the exhaust choke so its causing it to run lean
Old Oct 28, 2016 | 04:28 PM
What manifold is on there now?
Old Oct 28, 2016 | 06:17 PM
72delta88's Avatar
stock 2 barrel with a carb adaptor
Old Oct 29, 2016 | 06:52 PM
That is not going to work well. I bet its flooding and that's contributing to your backfire.
Old Oct 29, 2016 | 07:00 PM
76olds's Avatar
Hookers under Hood
Gettin' on er' and puttin' er' up to 6500 RPMs isn't going to help it much either haha!!
I'd think about gettin' on something else if you have that much energy, maybe somethin' in the back seat. Jus' sayin'
I've wipped springs out of back seats back in the day, pffft while flyin'
Put-er-ther
Eric
Old Oct 29, 2016 | 07:06 PM
72delta88's Avatar
got it fixed timing was retarded to far back
Old Oct 29, 2016 | 07:07 PM
72delta88's Avatar
I've wipped springs out of back seats back in the day, pffft while flyin'so its not accurate
Put-er-ther
Eric
haha just for the record I wasn't driving my girl was needless to say my tach is 600-750 high and its sticky
Old Oct 31, 2016 | 07:05 AM
jpc647's Avatar
Careful turning a stock SBO that high. Thats ~5800 rpms. That's still high.
Old Oct 31, 2016 | 08:11 AM
TripDeuces's Avatar
So you have a Holley 4bbl going into a carb adapter into a 2bbl manifold?
Old Oct 31, 2016 | 08:47 AM
72delta88's Avatar
yea not the best way to go I know but the car was on the side of the road and it was 2 weeks before the parts store could get a 2 barrel I'm goin to a 4 barrel intake longtube headers and dual 2.5 in exhaust in december
Old Oct 31, 2016 | 04:39 PM
76olds's Avatar
Hookers under Hood
That should wake your 350 up some. Your neighbours will really hear you after that.
Have you got the cam/chain sorted out?
Old Oct 31, 2016 | 05:16 PM
72delta88's Avatar
I'm not sure its running ok though
RustRocket
Sep 5, 2014 10:14 PM
Iggyg00
Jun 18, 2014 08:35 PM
VinMichael
Feb 20, 2014 07:33 PM
Hank
Apr 15, 2013 07:13 PM
silverhurst
Dec 27, 2011 04:53 AM
