converting a 350 rocket to tbi
Old Oct 28, 2016 | 04:05 PM
72delta88's Avatar
ive got a tbi set up from a 5.7 chevy is there any way to make it work on a 350 rocket
Old Oct 28, 2016 | 05:42 PM
cutlassefi's Avatar
Will it run? Most likely yes. However it won't even be close to optimum without a different chip etc.
Old Oct 28, 2016 | 05:44 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Yes, there is. You need a distributor off a 80's CCC 307. The wire colours will match but the plug is different and the extra black wire is ground. Otherwise all the sbc sensors will work.
Old Oct 28, 2016 | 05:49 PM
72delta88's Avatar
I may just spring for the msd atomic efi ive already got msd parts on it
Old Oct 28, 2016 | 06:14 PM
If you have the $$$ the aftermarket set ups are much easier to tune to your set up.
Old Oct 28, 2016 | 06:16 PM
72delta88's Avatar
I'm goin to upgrade it over time
Old Oct 29, 2016 | 05:15 AM
cutlassefi's Avatar
If you're going to upgrade over time then don't buy the Atomic. You should get the Holley instead. You can upgrade that all the way to a multiport if you want to. Can't do that with the others.
And virtually all aftermarket systems are compatible with MSD parts.
Old Oct 29, 2016 | 07:55 AM
72delta88's Avatar
another reason I'm goin msd while I do see your point about holley I'm goin to need a trans controller when I change the drivetrain
Old Oct 29, 2016 | 10:14 AM
cutlassefi's Avatar
One system, one controller for everything.
https://www.holley.com/brands/holley...ssion_control/
Old Oct 31, 2016 | 07:35 AM
distributorguy's Avatar
FITech (not EFI Tech) works great. I just fired one up, stayed running on the first click of the key, tunes as you drive. And soon you WILL be able to convert it to multiport. No learning curve on this one, other than adjusting the throttle blade screw screw to get the IAC setup right.
Now here's where I get bashed by cutlassefi...
Old Oct 31, 2016 | 07:40 AM
cutlassefi's Avatar
I NEVER "bash" anyone unless they're spewing crap. Or if they've done something one time and are now an "expert".
Old Oct 31, 2016 | 09:46 AM
...or if they have a different opinion than you.
Old Oct 31, 2016 | 02:58 PM
cutlassefi's Avatar
Please show me where I crucified someone for their OPINION, not spewing crap that they claim is fact. Like I've said many times, if you can support what you say with hard facts, I'm all ears. Everybody learns that way.
Old Oct 31, 2016 | 03:57 PM
72delta88's Avatar
ENOUGH BOTH OF YOU we all have different parts we like or dislike
Old Oct 31, 2016 | 05:02 PM
cutlassefi's Avatar
You're right, sorry for the hijack.
Old Oct 31, 2016 | 05:15 PM
72delta88's Avatar
no harm no foul
Old Oct 31, 2016 | 05:51 PM
I am surprised they run as well as they do without any timing control. It is nice to see TBI set ups for under $1000 on the market.
Old Nov 3, 2016 | 05:30 AM
For $1000 you DO get timing control with the FITech. For $800 you don't. Since I recurve distributors for a living, I don't want timing control. That allows me more opportunity to develop advance curves that work. In this case, since the throttle body flows more air than a Quadrajet, the advance curve needs to be modified slightly from what used to work.
How does it work? Beautifully! I don't have many miles on it yet, but every drive improves the fuel mixture and makes more power. Having played with FAST, Megasquirt, and modified factory systems, this is SO much easier and the end results are equal if not better. The self-tuning algorithm is slower than the one in MS systems, but its working well, and it errs on the safe (rich) side.
Old Nov 3, 2016 | 06:13 AM
I would rather have timing control that changes with the conditions and a included knock sensor would be that much better again. It looks like the Sniper won't work with the CCC HEI but can work with a locked out MSD or their $450 dual sync distributor to control timing, according to their instructions. I also have to decide on either the Robbmc Powersurge or an EFI tank and pump. If I start with a 2 grand system, it can creep up to 5 grand awful fast with all the extras.
Old Nov 3, 2016 | 05:41 PM
cutlassefi's Avatar
[QUOTE=distributorguy;965617]For $1000 you DO get timing control with the FITech. For $800 you don't. Since I recurve distributors for a living, I don't want timing control. Why not? That allows me more opportunity to develop advance curves that work. You can NEVER, REPEAT, NEVER duplicate on a conventional distributor what you can on a good EFI spark map, NEVER. In this case, since the throttle body flows more air than a Quadrajet, the advance curve needs to be modified slightly from what used to work. And that would be best done by the ECU.
[QUOTE]
To everyone else, it may put distributorguy out of business but spend the additional $200.00 for spark control, you'll be glad you did, I promise.
marxjunk
Jul 8, 2016 06:45 AM
Gary's 2 442-S
May 1, 2013 03:53 PM
78cutlass
Oct 13, 2011 06:38 PM
delkron97
Brakes/Hydraulic Systems
May 18, 2006 08:20 AM
72 Delta 88
Sep 2, 2002 08:49 PM
