looking for front oil seal
Old Nov 13, 2013 | 06:04 PM
Macadoo's Avatar
I'm looking for the crankshaft seal that fits inside the timing cover of a '71 350. I can't seem to find one. Unless it's this one:
http://www.rockauto.com/catalog/more...767&cc=1435198
Thanks guys
Old Nov 13, 2013 | 06:14 PM
72cutlassconv's Avatar
It also comes with the Victor Reinz timing cover sets
http://www.rockauto.com/catalog/more...190&cc=1435198
Old Nov 13, 2013 | 06:58 PM
That seal will come with any timing gasket set and with any full gasket set.
Since you took the engine apart to regasket it, I must assume that you've bought one of these.
It's a standard seal, so knowing the dimensions, you could easily get one from a number of other sources if you needed to.
Old Nov 14, 2013 | 04:16 AM
Macadoo's Avatar
Nope, didn't come with mine. But I didn't buy a set. Is the rockauto correct then?
Old Nov 14, 2013 | 04:46 AM
Any seal listed for an Olds 260, 307, 330, 350, 400, 403, 425, or 455 from FelPro, Reinz, or any other brand, from any supplier, including your local parts stir, should be fine.
Old Nov 14, 2013 | 08:48 AM
Thanks guys
Yes, that is correct. Fits every Olds V8 from 1964-1990. I would also recommend the balancer repair sleeve (National P/N 88199) if there is any scoring on your balancer where the seal rides.
Old Nov 14, 2013 | 01:58 PM
Macadoo's Avatar
Oh, so that's what that is. It kept coming up in my search. Thanks for the tip joe, I'll take a look at the balancer.
Old Nov 14, 2013 | 02:02 PM
Professur's Avatar
I'd get the sleeve either way. If you don't need it today .. you will sooner or later.
smcurro
Mar 16, 2018 08:37 PM
allyolds68
Jun 13, 2014 05:28 PM
trackz man
Jul 17, 2011 10:08 PM
Sixoh
Aug 8, 2006 05:11 AM
