Header install
Old Nov 14, 2013 | 09:19 AM
oldzzy's Avatar
wait.... what....
Header install
Hey guys, well i finally got a chance to install my SB ARH's today, and they are hitting the drivers side motor mount right on the top of the mount. I really don't want to ding up the header, so i am looking for suggestions. I thought about cutting the rubber, and grinding the steel on the motor mount but i figured that the mount was designed like it is for a purpose. The motor has Edelbrock heads, and new motor mounts.
Old Nov 14, 2013 | 11:07 AM
brownbomber77's Avatar
Grind a little of the mount back, sometimes the mounts they use in production of the headers I imagine aren't the same ones that are available in every single parts store. That, and variation between motor mount manufactures can cause issues like this, as well. Just grind it back a little, see what happens. Unfortunately, the driver's side takes the most of the force when the engine is at full throttle.
Old Nov 14, 2013 | 12:02 PM
chadman's Avatar
Just use a solid mount on the drivers side. It will give you more clearance and limit motor movement at the same time. That is what I run.
Old Nov 14, 2013 | 01:24 PM
Stevec's Avatar
Hey chadman where can I get a set of solid motor mounts? What are the pros and cons?
Old Nov 14, 2013 | 03:54 PM
380 Racer's Avatar
Pros.......it keeps the motor from twisting.
Cons.......it puts added stress on the area of the #4 main web and can crack.
Old Nov 14, 2013 | 04:09 PM
Stevec's Avatar
What would you rec for a 540 or so hp street engine?
Sorry oldzzy didn't mean to high jack your thread.
Old Nov 14, 2013 | 04:17 PM
11971four4two's Avatar
MOTORHEAD
bill was making mounts
https://classicoldsmobile.com/forums...tor-mount.html
Old Nov 15, 2013 | 04:34 AM
chadman's Avatar
Just to clarify I only run a solid mount on the drivers side. The other side is a standard mount. The drivers side is the one that takes the stretching force. This gives you more vibration damping than all solid. Like Nick said, some claim solid mounts can stress the block but I don't see it as a problem at the street/strip power level. I know guys running solids at much higher power levels than me without issues.
Old Nov 15, 2013 | 08:05 AM
oldzzy's Avatar
wait.... what....
N/P i am also curious as to where to get a solid mount. I pm'd Bill, I am just waiting to hear back from him.
Old Nov 15, 2013 | 08:52 AM
chadman's Avatar
I could build you a solid mount. It is really quite simple. Three pieces of 5/16" thick steel, four holes and a couple of welds.
Old Nov 15, 2013 | 10:12 AM
380 Racer's Avatar
Granted mine wasn't a street motor. Higher RPM launches but shyt does happen .
leroycjr
Body work
May 1, 2015 09:18 AM
arodenhiser
May 8, 2014 05:49 AM
yankees
Aug 25, 2013 07:03 PM
67Olds442X2
Feb 2, 2011 07:12 PM
1964F85
Jul 29, 2010 06:37 AM
