Is this normal?
Old Oct 28, 2013 | 04:31 PM
Macadoo's Avatar
Is this normal?
I've pulled my engine, as many of you know, i'ts on the stand and I'm disassembling. Heads, intake, timing set, etc. are still on the motor. Really the only things I've gotten off so far are the exhaust manifolds.
I turned the motor upside-down to remove the oil pan, got it off and was turning the crank when some oil came out the intake manifold, a vacuum fitting I think. And the #8 exhaust port is full of oil. Should I be concerned?
I'm planning on taking the heads in to get them cleaned up with new seals, etc.
Thanks guys.
Old Oct 28, 2013 | 04:35 PM
Weird. Are you sure it's from the intake and not the distributor hole?
Old Oct 28, 2013 | 04:38 PM
Macadoo's Avatar
Yeah, I checked tonight. Turned the crank again and got a few drips from one of the rectangular fittings on the intake.
Old Oct 28, 2013 | 05:14 PM
Perhaps a picture may help.
Old Oct 28, 2013 | 05:17 PM
Macadoo's Avatar
Will do....
Old Oct 28, 2013 | 05:27 PM
Professur's Avatar
You really expect anyone here to know what normal is?
just thinking ... when you drained the motor ... did you remove the oil filter?
Old Oct 28, 2013 | 05:31 PM
Macadoo's Avatar
This is the amount of oil that poured out when the crank was turned about three full turns...
[IMG][/IMG]
Here you can see oil drips on a couple different fittings. And I had forgotten, I plugged the distributor hole when I was cleaning the block.
[IMG][/IMG]
The #8 exhaust port....
[IMG][/IMG]
I hope this helps.
Old Oct 28, 2013 | 05:32 PM
Macadoo's Avatar
Yeah Prof, the adapter is off as well.
We are all normal in our own little way..
Old Oct 28, 2013 | 05:36 PM
It probably ran up the cylinder bores and past the rings. Is it engine oil or penetrant? You sure you drained it?
Old Oct 28, 2013 | 05:43 PM
Macadoo's Avatar
Drained the oil? Lol, yeah, I'm sure. Is that a bad sign for the rings?
Old Oct 28, 2013 | 05:44 PM
Macadoo's Avatar
I used to live in Normal Illinois
Old Oct 28, 2013 | 05:46 PM
Professur's Avatar
For it to get there through the rings would mean it was still in the pan when you flipped the engine ... There would have been some oil left between the oil pump and the filter housing ... but not that much.
Old Oct 28, 2013 | 05:47 PM
It's never happened to me, Ive always had the intake and heads off before flipping it. I do know that oil will pass the rings when a car is upside down. Been there and done that.
Old Oct 28, 2013 | 05:53 PM
Macadoo's Avatar
I'm not going to worry about it. The wet test came back fine. There might have been some oil in the pan but I drained it for a day and took the filter off before pulling the engine. I turned the engine over on the stand before pulling the heads to ease the cleaning. I'm wondering if I'll get it back up with the heads still on. :-/
Macadoo's Avatar
Wait Oldcutlass, what?! You flipped a car?
Old Oct 28, 2013 | 05:59 PM
Did the engine run well before you started messing with it? If I recall, it did.
So, don't worry about it.
Old Oct 28, 2013 | 06:14 PM
Macadoo's Avatar
When the float wasn't sticking, yes, it ran very smooth with no smoke out the tail pipe. I just wanted to make sure the block wasn't cracked or something. Thanks fellas.
Old Oct 28, 2013 | 06:32 PM
In that case, there's no way that that much oil could be coming from someplace bad.
Old Oct 28, 2013 | 06:42 PM
Professur's Avatar
exactly how much oil did you pour into the plug hole for the wet test?
Old Oct 28, 2013 | 07:55 PM
nsnarsk65cutlass's Avatar
Even with the drain plug removed and oil drained there will be some oil left on the bottom of oil pan that will not drain out,the oil probably leaked past the piston as others have stated.
Old Oct 28, 2013 | 08:07 PM
I didn't flip one, my buddy did, A ford Ranger. It rolled over gently in a drainage ditch. I just pulled the spark plugs cranked it with the starter and blew all the oil out of the cylinders. Topped off the crankcase, cleaned the plugs, and fired it up.
Old Oct 29, 2013 | 12:52 PM
Macadoo's Avatar
Well I'm certainly glad no one was hurt :-)
Old Oct 29, 2013 | 12:55 PM
Macadoo's Avatar
I suppose 8 teaspoons adds up a little (one per cylinder). Again, if what Oldcutlass says about oil sliding past the rings when upside down is true, then I'm not going to worry about it.
Old Oct 29, 2013 | 04:37 PM
M-14's Avatar
Some of it might be from the rings & some just might be whats left in the intake from the pcv valve, I've pulled a lot of intakes on different engines & seen oil puddling. Some how it just doesn't get sucked into the combustion chamber.
Old Oct 29, 2013 | 04:41 PM
M-14's Avatar
I've seen this on buick 3800s that don't burn oil, look at the top left area.
Old Oct 29, 2013 | 05:23 PM
Macadoo's Avatar
Huh, I wouldn't have thought that. Thanks for the info M-14.
Old Nov 8, 2013 | 06:34 PM
Lars's Avatar
there is a lot of oil left in the motor after draining the pan, lifters, passages, crank, etc, it'll drip for ever. the oil in the intake port probably went by the rings into the combustion chamber, by an open valve into the runner, your fine.
STAYBG
19
Nov 2, 2010 05:34 AM
MDchanic
Sep 27, 2010 08:03 PM
gearheads78
Sep 10, 2010 02:26 AM
66ninetyeightls
Ninety-Eight
22
Aug 23, 2010 05:40 PM
nukesec1
Aug 9, 2009 02:08 PM
