My inventory - Not what it is supposed to be
Old Feb 5, 2014 | 12:26 AM
Nop's Avatar
Nop
2-stroke 1-cylinder guy
After removing my DS inner fender I was finally able to take a complete inventory.
I have a '70 Oldsmobile Cutlass Supreme with a 4bbl 350, originally high comression/~310BHP
My numbers so far:
VIN:
342570Zxxxxxx: a 1970 Fremont car.
Engine:
3955582: "Heavy casting" 350
30Zxxxxxx: '70 Olds, Fremont, VIN matches
TH350:
70 JL172 D, apparently the right "JL" for my car.
Oil filler tube:
0223247, also apparently from '70
Intake manifold:
404520 casted at the rear
So far so good. Now the more suspect things
Carb:
Quadrajet 17054938, a post-70 (74?) Cadillac (#3) carb for an automatic trans?!?!?
Heads:
#8 heads. Nooooo! The 73-76 79cc heads with 8:1 compression ratio.
Didn't drive a lot of miles so far, the Cutlass is torn apart at the moment, but I'd say it doesn't pull like a >250HP V8, be it SAE horse power or not...
I replaced my worn, crudded and misfiring points with a Pertronix, starts way better already. I'll check my ignition timing as soon as the car drives again, but timing looks good for now.
What am I going to do next? I definitely don't want to tear the engine apart right now and to be honenst I don't even want to pull my heads - too many MAWs piled up already.
I know, "no pain no gain", but what smaller tasks can I perform while working on the car 1-2 hours a day?
* See if I can get a glimpse of my pistons to see what top shape they have. What do I look for exactly?
* Hope that only the original (#5?) heads were replaced with #8 ones? Why would someone do that?
* Get a pair of correct (#5?) heads?
* Any ideas on all the #'s? Something else looking suspicious?
Thanks, guys and gals
Old Feb 5, 2014 | 12:40 AM
nsnarsk65cutlass's Avatar
What #s on the block that will tell you if the heads have been transplanted.Someone on here will know as i don't.
Old Feb 5, 2014 | 12:43 AM
Nop's Avatar
Nop
Sorry, I don't understand what you mean by that?
The heads are not the ones that the '70 4bbl 350 came with originally, so they're transplanted.
Old Feb 5, 2014 | 01:08 AM
I missed 3955582 on your first post then i'd say yes someone replaced the heads with later ones.Also carb 1705 #s are 1976-79 not sure on the rest 4938.
Old Feb 5, 2014 | 03:26 AM
Photographs might help us to assess your entire set-up.
You can also look inside the spark plug holes with a scope to see the pistons - the should have a V-shaped notch on their front edges if they are high compression.
I don't want to think about how much it would cost to ship a pair of heads to Europe.
Old Feb 5, 2014 | 03:53 AM
Nop's Avatar
Nop
So I'm looking for the low-dish pistons with a small V-shaped notch, 1st row middle picture?
What other pictures would you like to see?
Ah, peanuts!
What original heads would I look for? #5?
Old Feb 5, 2014 | 04:15 AM
Correct. It's not hard to see with a bore scope or similar device.
Old Feb 5, 2014 | 04:40 AM
tru-blue 442's Avatar
Old School Olds
# 6's would be the correct
heads for 1970.
Old Feb 5, 2014 | 06:21 AM
heads for 1970.
True, but from a functional perspective, 5s, 6s, 7s, or 7As should all work as well, if you are able to find any "over there."
Old Feb 5, 2014 | 06:22 AM
Old School Olds
Agreed.
Old Feb 5, 2014 | 10:57 AM
Nop's Avatar
Nop
OK, my USB bore scope will arrive tomorrow.
Old Feb 6, 2014 | 11:32 AM
Nop's Avatar
Nop
Additional info: The intake manifold is a iron #10, casting 404520 - didn't find any info about it besides it is a standard '70 manifold.
Here we go:
Took a random shot at cylinder #4 with my new amateur gynecologist USB gadget, bingo:
Looking at the printed chart I posted this looks like a shallow dish to me. Plus one V-shaped notch. Do you agree?
Last question: Why would someone put the high-cc heads on? Afraid of horsepower?
Old Feb 6, 2014 | 12:35 PM
Yes, those look like shallow-dish pistons to me, with the correct V-notch, but, boy are those pictures hard to see.
As for why change the heads?
Three reasons I can think of off the top of my head:
1.) Original heads were no good - loose guides, leaking, burned - and these were the cheapest / easiest replacements to find
2.) In the early 1980s, when there was no high octane fuel available, they were changed to prevent detonation
3.) Somebody wanted the #6 heads, and took them before selling the car.
Odds are you'll never know.
If you replace them with correct heads and correct steel 0.016" (0.4mm) head gaskets, you will probably need 100 octane gasoline (using the current European octane rating scale), but if you use a regular FelPro 0.043" gasket, you may get away with using 98 octane.
Old Feb 6, 2014 | 12:44 PM
Nop's Avatar
Nop
Tilt your screen or stand up for better contrast... I'll try to get some better pics outta that awesome $12 device.
Old Feb 6, 2014 | 10:07 PM
Nop's Avatar
Nop
Good morning.
Does anybody have a nice pic of a clean HC piston crown? Yes, that scope is crap basically, but with an image for comparison it'll be easier.
Used 102 ROZ/88 MOZ (Euro) plus lead additive for the first two fills, as I assumed high compression. I'll stick with that.
So apparently there's no common cause I didn't know besides the obvious reasons, OK.
I'll have a look for 5/6/7/7<sub>A</sub> heads then.
Old Feb 7, 2014 | 01:41 AM
Hard to see but to me looks like a lot of pitting ?or detonation wear on the piston?
Old Feb 7, 2014 | 02:04 AM
Nop's Avatar
Nop
From the cam's live video that looks a bit clearer than the stills I rather think it's a thick flaky coal crud.
Circled a supposed chipped off flake of coal.
What seems strange to me is the gap between cylinder wall and piston crown - it looks rather large in relation to the bore radius?
Engine is running very very smooth though without rattling or any other strange sounds like .25 piston clearance
Last edited by Nop; Feb 7, 2014 at 02:12 AM. Reason: 20863 edits later - Lost my English abilities completely over night
Old Feb 7, 2014 | 03:03 AM
Yeah, as nsnarsk65cutlass said, it's really hard to say anything about the surface because of the photo quality. If everything is working well, I wouldn't worry about it now, and if you're going to replace the heads, you'll see them directly soon enough anyway.
Last98
Aug 4, 2013 05:46 PM
tmatador
Aug 9, 2011 09:37 PM
Dave Siltman
Jul 19, 2011 09:22 AM
wdgraham1
Jun 26, 2011 08:51 AM
ChrisM
Sep 11, 2008 08:45 PM
