Stock Intake Manifold
Old Feb 4, 2014 | 12:08 AM
RonzBoyz4's Avatar
Team,
Intake Manifold (Stock Aluminum )84-86 307
While shopping at the local junk yard outside of Carson, I noticed an aluminum intake on a Buick, that looked stock. Moreover, it looked like my Olds intake. I pulled it and it is.
I am rebuilding my 68 350 and want an opinion.
Q. Is it worth cleaning up, or should I just buy a 3711(1)?
Car: 1980 Olds Cutlass Supreme
Engine:
1968
350 #5 Heads
Electronic Distributor
Q-Jet 800
Related article:
A4 Stock Olds Aluminum Intake
http://performanceolds307.tripod.com/id29.html
Old Feb 4, 2014 | 03:28 AM
J-(Chicago)'s Avatar
Seasoned beater pilot.
If it is an A4, go ahead and use it if you want to save a few dollars.
If it is an A5, I wouldn't bother. The a5 intkae was 1985-newer.
I don't think the a4 is any better than your stock iron manifold though, and if you have a divorced choke setup on your carburetor, it won't have that provision.
Old Feb 4, 2014 | 06:28 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Agree, if it is a 800 cfm Qjet, it should be a late 70's model with hot air choke. I always convert them to electric. Not sure why Olds stayed with the hot air till the bitter end.
Old Feb 4, 2014 | 10:27 AM
RonzBoyz4's Avatar
Team, It is an A5.......
The Q-jet is off a Caddy.
It runs very rich, MUCH carbon build up, soI plan to go down to a 600-750.
Thoughts??
Old Feb 4, 2014 | 12:15 PM
DoubleV's Avatar
All you need to do is tune the Qjet you have and it will work like a champ. The Qjet may seem big at 800, but because of the way it works it will give you the drivability of a smaller carb. Remember, they had 800 Qjets on 307 smogger 80's engines. It's all in how they're set up. Taking a worn out Qjet off of engine X isn't usually going to work well on engine Y untill you rebuild it and do some re-jetting/tuning.
Old Feb 4, 2014 | 04:15 PM
Look at the ports on the a5, they're way smaller than your stock manifold. Throw the a5 in the trash.
Old Feb 4, 2014 | 11:44 PM
RonzBoyz4's Avatar
DoubleV, Q-jet, tracking!
Walking the dog last night I had the revelation, tune it up, the front hald is economy, back half, tighten the spring a little more... " the motor draws, so make it a little tighter" kind of thing.
Thoughts?
Th
Old Feb 4, 2014 | 11:49 PM
RonzBoyz4's Avatar
Intake Manifold- A5 v.s. 2711/3711
"Throw that A5 in the trash"
I'll have to keep it until I locate an A4, equal or better....
Thanks all for your input.
1971viking
Jul 8, 2011 05:33 AM
69442C
Jan 10, 2011 04:49 PM
oldzy
Oct 1, 2010 11:08 PM
Gaz Hog
Apr 22, 2010 07:49 AM
kmccox11
Feb 27, 2009 06:51 PM
