slow crank problem
Old Oct 17, 2013 | 07:25 PM
brettb's Avatar
slow crank problem
Okay this is not about my olds its about my 1976 Chevy Monte Carlo 400small block... It started to crank slow or even skip a crank and then start. The car starts I've replaced the battery with an Exide AGM drycell with 800 cranking amps and replaced the alternator. Could my starter be going out? I also hear a whinding sound around my transmission which i causing my fuel to get sucked down like crazy. Could my starter be stuck engaged and not retracting and causing my transmission to whine? Still shifts thru all gears fine no slip and the fluid is good and full in the trans...Any thoughts? Or suggestions? Thanks
Bernhard
Nov 24, 2022 09:12 AM
88olds350
Mar 6, 2014 05:33 PM
Bernhard
Jan 6, 2013 09:27 PM
sx455raidercelticfan
Nov 23, 2010 05:45 AM
wolfman98
Site Help
Nov 19, 2009 05:06 PM
