Spark Plugs
Old Jun 12, 2012 | 08:35 AM
Doomah's Avatar
Spark Plugs
I was going to change my spark plugs but I am un sure which ones to get. I have a MSD ignition but I am going to change it to a mallory one, so I need to know what plugs to get. Should I be getting a reach of 3/4 or 3/8?
Anyways thanks. O yea I have a 1969 350
Old Jun 12, 2012 | 02:30 PM
oddball's Avatar
You don't necessarily need to change plugs just due to a distributor/coil change. You might be able to experiment with wider spark gaps.
As far as dimensions and style of plug, that should go with whatever heads you're using. I defer to others here, but AC Delco R45S's are pretty common applications.
Old Jun 12, 2012 | 05:52 PM
cutlassefi's Avatar
Same as above except always use the coolest plug you can before they foul. I'd try a R43S, you might be able to add a bit of advance with a cooler plug.
Old Jun 15, 2012 | 10:31 PM
SBORule's Avatar
NGK R5 U Groove plugs.
bob p
Apr 10, 2015 01:55 PM
maquis1431
Sep 27, 2008 10:42 AM
65Delta88
Sep 11, 2008 10:13 AM
KQQLCAT
May 6, 2008 08:18 PM
The_Jeremiah
Jan 26, 2008 01:56 AM
