High RPM Backfire/stumble/loss of power
Old May 29, 2012 | 11:05 AM
69350rocket's Avatar
Ever since I have gotten my car it has had no power on the top end. If I go full throttle at about 3500-4000 it just falls on its face. If I keep in it it will either backfire out the exhaust or through the carb, and just keep doing it. I have had some people tell me its valvesprings and some day ignition problems. I could kinda see how either one would make sense. My car has an Accel HEI if that makes any difference. What do you guys think?
Old May 29, 2012 | 11:19 AM
rcrac3r's Avatar
I would start with simple stuff like checking timing, check plugs/wires, etc. Has the camshaft ever been replaced? I've seen where a camshaft with a worn lobe or 2 will cause backfire up through the carb, like it's spitting at you, when you rev it up.
Old May 29, 2012 | 12:35 PM
Timing is already set. Have replaced the plugs but not the wires. The engine is pretty old and worn, it was rebuilt at some point so I will assume the cam has been replaced, but not positive. I will be replacing the 350 with a big block in the next few months so if its anything too serious I wont really worry about it.
Old May 29, 2012 | 01:47 PM
Rickman48's Avatar
Sounds like 'valve float' to me - springs or lifters, but could also be wires!!
If it gets worse when it's raining, it's the wires.
If that fixes it, fine - if not, take it easy 'til the BB's ready!!
rdhigh1974
Dec 24, 2014 05:31 AM
455Eldorado
May 19, 2011 09:57 PM
turnpike_cruiser
Jun 22, 2010 08:54 PM
64starfire
Jun 1, 2009 10:32 PM
W30post
Nov 30, 2007 02:46 AM
