intake swap
Old Jun 24, 2012 | 04:12 PM
wills30's Avatar
intake swap
i have a 330 in my 67 cutlass. i currently have a two barrel , in it now and i want to switch,to a 4 barrel . is the linkage the correct for the 2 as the 4 . or do i need anther linkage? i am switching to anther factory 330 olds intake ,
Old Jun 24, 2012 | 06:42 PM
You may have to come up with a longer rod. 67's are pretty simple, just make sure that when you install the new carb, prior to connecting the fuel line, make sure you are getting WOT (wide open throttle). Then make sure your switch pitch, and down shift signals are there.
Old Jun 24, 2012 | 07:36 PM
wills30's Avatar
thanks just want to make sure ,brackets were the same ,before i started and found out ,something else was different.linkage is obtainable
Old Jun 25, 2012 | 06:17 AM
On your intake gasket there are two types, 1 is a turkey tray, the other is a 4 peice for an engine that comes with a tray in the lifter galley area. When you pull your manifold, note which you have and purchase accordingly.
xbody
Sep 18, 2020 09:03 AM
'69CutlassVert'
Aug 25, 2011 07:19 AM
svnt442
Jul 17, 2011 04:43 PM
gumbyssfakee
Dec 9, 2008 06:50 PM
cutlassinvt
Jul 7, 2008 10:54 AM
