Limiting the HEI mechanical advance
Old Jul 14, 2012 | 10:45 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Ok so I need to limit my mechanical advance on my HEI. I have around 25 base and 36 at 3000 which is OK. Problem is it gains at least 2 degrees at 4000 rpm. I have seen the brazing method, last resort. Has anyone tried the screw method in the mechanism's base to limit travel? I found it on chebby sites, should be the opposite side for us? Any thoughts? This on my Olds 403 in my signature.
Old Jul 23, 2012 | 09:35 PM
The screw method does work but my Mallory ignition works better. Mark sent me the parts I needed, all is good.
Old Jul 24, 2012 | 06:07 AM
joepenoso's Avatar
What's the screw method it sounds like it could be fun..............and who is Mark?
joepenoso
Old Jul 24, 2012 | 05:09 PM
Cutlassefi is Mark. The screw method basically limits the mechanical advance travel, not as fun as you think. I put the lightest pink springs in the Mallory breakerless SS distributor and used the 16 degree tuning key. 23 base, 36 total in by just over 1500 rpm! My low compression 403 can tolerate a lot of timing and my converter stalls just over that rpm. This and the rejetted carb should yield positive track times.
joepenoso
Jun 4, 2014 01:56 PM
WTony
Jun 29, 2013 05:11 AM
DasBaldDog
Mar 1, 2013 10:20 AM
MDchanic
Oct 4, 2010 07:40 AM
The Stickman
Feb 19, 2009 01:23 AM
