Getting my heads milled?!
Old Jul 19, 2012 | 06:56 AM
dancutlass's Avatar
I'm in the progress of replacing the head gaskets on my '66 high compression 330 engine. As far as I know everything is stock.
I ordered the Mr. Gasket Ultra seal head gaskets with a compressed thickness of 0,038i http://www.summitracing.com/parts/MRG-5788G
Now the question is if I should mill my heads to compensate for the thicker head gaskets? And if so how much?
As always any answers will be greatly appreciated!
Old Jul 19, 2012 | 07:26 AM
Rickman48's Avatar
I'd just do a 'clean-up cut' on the heads, unless you've got better than 93 octane fuel available.
Sure, you're reducing some compression, but modern fuel is junk, compared to what that motor was designed to live on.
If you're bringing the car back with you, all the better!
Old Jul 19, 2012 | 07:58 AM
dancutlass's Avatar
Okay thanks Rickman!
I can choose between 95 octane fuel and 98 octane fuel but it's the ROZ not the MOZ...
But will I feel any power difference because of the reduced compression?
Old Jul 19, 2012 | 08:43 AM
cutlassefi's Avatar
98 RON is roughly equal to our 93. I'd just do a clean up cut as discussed.
Old Jul 19, 2012 | 09:06 AM
Rickman48's Avatar
I doubt you'll feel a difference - if you've loud mufflers, it might be a decible quieter.
I once took .010 off a pair of 283 fuelly heads with 12 1/2 pistons - MUCH LOUDER!
Old Jul 19, 2012 | 09:42 AM
dancutlass's Avatar
A whole decibel?! I doubt that I feel a difference, too, as I've only driven the car for about 10 minutes so far
I'll let them do the clean-up cut then! Many thanks for your advice, Rickman and Mark!
Old Jul 20, 2012 | 11:54 AM
dancutlass's Avatar
I forgot to ask if I have to change anything on my valvetrain due to the thicker head gaskets??
Old Jul 20, 2012 | 09:50 PM
64Rocket's Avatar
If it was me I would cut .020 off. Just to compensate for the thicker gasket.
But that is me.
Gene
jag1886
Oct 22, 2013 06:15 PM
f-85
Aug 15, 2010 11:15 AM
f-85
Jul 31, 2010 04:54 PM
Moofinator
Ninety-Eight
28
Jun 4, 2007 09:13 PM
muttmeg
Ninety-Eight
Apr 21, 2007 09:26 PM
