Trans and drive shaft
Old Jun 14, 2012 | 07:02 PM
805cut's Avatar
How do i disconnect my trans from my drive shaft??
Thanks!!
Old Jun 14, 2012 | 07:18 PM
  1. Remove four nuts from U-bolts on rear universal
  2. Remove U-bolts
  3. Dislodge universal from driveshaft yoke
  4. Pull driveshaft out of transmission
  5. Say "Oh #&@)@*!!!!" and run to find lots of rags as oil pours out the back of your transmission.
Old Jun 14, 2012 | 08:20 PM
805cut's Avatar
  2. Remove U-bolts
Ha thanks man, i figured it out.. I was starting at the front !!!!
Old Jun 14, 2012 | 08:21 PM
805cut's Avatar
No tranny fluid tho.. Wthat the heck dose that mean?
Old Jun 14, 2012 | 08:27 PM
Coche no va.
Old Jun 14, 2012 | 11:17 PM
ah64pilot's Avatar
Coche no va y tranny no trabaje...lol!
No fluid, either the previous owner did you a favor by draining it before he sold it or you're REALLY low. You'll find fluid when you pull the motor...in which case you'll scramble to find rags and then smash your distributor into the firewall. But according to Eric you can always remove it afterwards
"Remove distributor (unless you're really sure you won't smash it against the firewall, in which case you can remove it after you smash it against the firewall)."
Old Jun 15, 2012 | 07:45 AM
805cut's Avatar
Ohhhh there was tranny fluid, dont know why but its alllll over the garage this morning... Love it
Old Jun 15, 2012 | 05:02 PM
Nasty455's Avatar
XCELERATIONRULES!
Remove trans pan and remove fluid and filter.
It's a lot easier collecting the fluid before it hits the garage floor.
Old Jun 15, 2012 | 05:23 PM
Rickman48's Avatar
You'll also find running some tape around all the u-joint cups will now keep the loose 2 from falling off and the needle bearings from scattering all over a 20 x 20 garage, and you'll be 1 short, everytime!
We've all done it!
Old Jun 16, 2012 | 07:12 AM
We've all done it!
Actually now would be a good time to just go ahead and replace the U-joints if it's been a while!
67Rocket
Drivetrain/Differentials
Jul 30, 2015 10:06 AM
Wayne Shipley
Dec 6, 2014 10:03 PM
Frogge467
Mar 24, 2012 11:09 PM
64 CUTLASS KEN
Nov 22, 2010 05:17 PM
68conv455
Apr 11, 2008 11:48 PM
