350 block help please
hey my 350 block and crank and cam,2 connecting rods in my 69 cutlass is dead, ive got a chance to get my hands on a 75 olds 350 short block ,crank and cam and rods, well the question is will the rest of my parts fit the new engine??is their difference in blocks?? ect ect from aus hard to find anything here without impoting??any help would be appreciated thanks
It's mostly all the same stuff. The pistons are different so don't just take them out of the 75. You can either use the 69 pistons (if they are in good shape) or use the 75 pistons, but you will loose some compression doing this.
Are you sure about that, Randy? If he has a low compression 69 350, don't the pistons have the same 14 cc dish? If it is a high comp 350 with the 6 cc dish, then they are different. They lowered the compression in the 73-73 engines with the large 80 cc chamber in the #8 heads. If the 75 short block is in decent shape, put the 69 #5 heads on it (after a good valve job) and your Cr should be 8.6 to 1 +/-
Well in my 70 service manual there are 3 pistons listed and we know (most likely) he doesn't have a W31 so we can rule out the flat tops. That would leave the 4 barrel high comp 6cc and the low comp 14cc. For some reason I thought the 73-76 pistons were cavernous, but you may be correct and they could be the same as the older ones.
I haven't messed with a 350 for A LONG time so I get a little forgetful.
1BAD68"S"
Sep 17, 2006 06:49 AM
