header bolt size 70 cutlass
Old Mar 28, 2010 | 11:54 PM
Kidcutty's Avatar
Easy Does It!
Hey guys quick question,what's the header bolt size on a 70 cutlass?
Old Mar 29, 2010 | 08:54 AM
Run to Rund's Avatar
3/8 x 16, 3/4" or 1" long depending on header flange thickness. Longer with stock manifolds, probably 1.25" will work; depends on washer thickness somewhat. Try for 1/2" or so of threads into the head.
Old Mar 29, 2010 | 09:06 AM
80_cutlass's Avatar
Good thing is if it is just a little too long they are thru bolts, so you should be ok. I like to use a thick washer like the ones on the center bolts of the dreaded tubular exhaust manifolds whenever it is feasible to spread the force of the bolt.
So, I ended up using 3/8 NC x 1.25" on most all of the bolts.
sb
Old Mar 29, 2010 | 10:12 AM
Kidcutty's Avatar
Easy Does It!
re
For you guys who've done headers,do you feel thread lock should be used on bolts? And have any of you tried the super seal geader gaskets from mr.gasket? I had those on my transam,but a bolt got loose and the heat disintigrated the gasket because of a tiny gap, what do yo recomemd?
Old Mar 29, 2010 | 10:20 AM
80_cutlass's Avatar
I have used, with good results on mopars, lock washers and the Remflex brand of gaskets. On slant sixes I have used the same type of material as remflex for both the manifold gasket and the "hot box" gasket from a company in Oz...but I digress:
http://www.remflex.com/
sb
Last edited by 80_cutlass; Mar 29, 2010 at 10:21 AM. Reason: fat fingered some things
Old Mar 29, 2010 | 10:42 AM
442Harv's Avatar
Mr. Gasket Ultra Seals work great.
Old Mar 29, 2010 | 03:23 PM
380 Racer's Avatar
Ditto
SD72cutlass
Suspension & Handling
Feb 13, 2018 05:27 PM
crank shaft
Feb 24, 2014 06:28 PM
rootney
Aug 21, 2013 04:24 PM
yankees
Jun 17, 2013 09:14 PM
Bernhard
Dec 17, 2012 04:07 PM
