vacuum lines, with stripes
Old Mar 4, 2010 | 07:03 AM
mmcilroy's Avatar
Red face vacuum lines, with stripes
Does anyone know of a source for color coded vacuum lines. I would like to replace all of mine but really would like to match the colors with the originals. Not so much for that original look, more so for my simple brain to trace them and make sure I got it all correctly connected. Or, as with most of the odd items will I just have to devise a way to stripe them myself. If that's the case has anyone rigged up something that worked.
Old Mar 10, 2010 | 03:05 PM
tjlaugh70's Avatar
I have been looking into this also. So for the way that I have heard it done is with a pin stripe kit. I am looking at doing the 3/16" vacuum motor line on the OAI on the 70 350.
Terry
Old Mar 10, 2010 | 06:18 PM
Lady72nRob71's Avatar
Like this?
http://www.shop.stevescamaroparts.co...oot-080382.htm
Or this?
http://www.heartbeatcity.com/store/p...-24--67-68-69/
I just googled vacuum hose "white strip".
Those camaro, vette, and rustang shops have almost everything under the sun - and some parts are shared with Olds!
And since it is available, it might can be had by special order from your favorite Olds parts house.
Old Mar 11, 2010 | 02:57 AM
Yellowstatue's Avatar
I used pencil crayons in my assembly manual to help me follow the cct also... use the right colour to match the stripe
Old Jan 11, 2013 | 09:52 PM
I know this is an ancient thread, but did you get what you were looking for? The vacuum lines you're looking for (color coded) can be purchased at ILT - In line Tube. You can also buy a Beugler pin striping tool to paint the stripes on the lines yourself.
StarfireFox62
Sep 25, 2008 01:29 PM
#1CutlassSupreme
May 14, 2008 04:28 PM
terribleonexx88
Mar 16, 2007 12:00 PM
Chumley
Jan 3, 2007 06:00 AM
bbock
Jun 5, 2006 11:50 AM
