403 coolant
Old Nov 6, 2009 | 05:14 PM
abram's Avatar
403 coolant
On the back side of the intake theres a "thing" (excuse my ignorance) that coolant will come out of, I think a heater hose connects to it but im not sure, can this "thing" be blocked off if not needed??
Al
Old Nov 6, 2009 | 06:12 PM
abram's Avatar
so i found out that the "thing" is a heater control valve, is it ok to block it off?
Al
Old Nov 6, 2009 | 07:40 PM
OldsMotion's Avatar
OldsMotion
Al
yes. If you do not plan on having heat in your car. Eliminating heat will cause you some fogging issues on a chilly morning.
Basically one side of the heater core runs into the nipple on the water pump, and the other side connects to that valve. If you block that off, then you will have to block off the water pump side as well.
John
Old Nov 7, 2009 | 11:44 AM
abram's Avatar
awesome, Thanks
88hurstolds
Jan 20, 2020 11:39 AM
465stroker
Jun 30, 2015 09:20 AM
ztim
Dec 22, 2006 10:20 PM
Redog
Dec 13, 2006 06:14 AM
Diabolus
Jul 23, 2004 04:35 AM
