Radiator overflow advice
Old Apr 9, 2010 | 06:43 PM
jtriggy's Avatar
Hi folks,
The brass (?) nipple that feeds my radiator overflow tube is slightly loose. Looks like the former owner had a zip tie holding it on!
Any simple advice to get the thing back solid without having to bring the radiator to a repair shop? Simple weld for the not-so-mechanically-inclined? I might be able to handle a hand-held soldering iron though.
Lemme know your thoughts please.
Thanks,
James
Old Apr 9, 2010 | 07:08 PM
Originally Posted by jtriggy
Hi folks,
Thanks,
James
No, not a weld. The rad uses solder joints. Drain out some coolant to lower the level. Clean up the area with a wire wheel so you have bare metal. Use some metal conditioner / cleaner to remove any oils or grease. Use some flux and solder with a torch to fix it back in place. Wipe off any extra residue. then just prime and paint black. Should work for you. If it doesn't, removing the rad isn't all that hard. Most rad shops will do a total inspection for a reasonable price. If you need a re-core you might as well get everything done at one time.
How old is the rad? DOes it look like it's in pretty good shape? Has it been pressure tested? All things to consider for a safe reliable cooling system.
Old Apr 9, 2010 | 09:58 PM
71 Cutlass's Avatar
One of None W-31
Allan R is right on the money. Have done this procedure before and it works perfectly.
Old Apr 10, 2010 | 04:52 AM
jtriggy's Avatar
Sweet. Thanks guys. Love classicolds!
mugzilla
Mar 29, 2010 12:10 AM
shockrebuild
Feb 26, 2010 10:18 AM
ilandtime
Jul 4, 2008 03:01 PM
silverriff
Feb 24, 2008 05:13 PM
oldssragtop
Nov 26, 2006 06:57 PM
