Oil Filter
Old Jan 21, 2010 | 05:51 AM
bittersweet71's Avatar
Oil Filter
I have always used an Ac/Delco oil filter.
Which brands do you think are best?
I am switching to Royal Purple and was wondering if the type of filter used needs to be changed as well.
Old Jan 21, 2010 | 05:59 AM
Destructor's Avatar
I remember reading that the AC filter is not very good anymore, I looked up a Purolator and didn't see anything listed fo my 70 Cutlass 350. The mobile 1 is overpriced. On other forums the consensus is that a lot of brands are junk. I beleive I also read that there is a Purolator which will work on a 70 Olds but I don't know the number.
Old Jan 21, 2010 | 07:44 AM
citcapp's Avatar
Napa Gold is the best as far as I am concerned
Old Jan 21, 2010 | 07:49 AM
Joeypete's Avatar
I use Bosch...I believe they are made by Purolator as well...It's a good filter and isn't outrageously expensive...about $6.99. I also read that about the only Fram worth considering is the Tough Guard series...but they are about the same price as the Bosch.
Old Jan 21, 2010 | 08:11 AM
I use Fram because it is orange.. I think they are all the same as long as you change your oil regularly. I think it is the same with oil. To each his own though.
Old Jan 21, 2010 | 08:19 AM
Joeypete's Avatar
Yes the color comes in handy when checking for leaks. The Bosch is black so doesn't show much...I have to occasionally wipe it with a towel to make sure I got it tight enough.
Old Jan 21, 2010 | 08:34 AM
bccan's Avatar
K & N, Amsoil, Mobil 1, Wix, NAPA Gold, Bosch all top notch, Baldwin always was but not sure anymore.
Old Jan 21, 2010 | 08:59 AM
kaz442's Avatar
Wix or Napa gold(made by Wix) or Baldwin. No questions. I wouldn't put a fram filter on a motor on a bet. They are just junk. Do a search on the net and see how many failures they have had. Jkaz
Old Jan 21, 2010 | 09:07 AM
My442's Avatar
1 quart filters:
WIX/NAPA - 1049/51049
Baldwin - B9
Old Jan 21, 2010 | 11:35 AM
I always run them and haven't had a problem. Maybe I'm just lucky.
Old Jan 21, 2010 | 07:44 PM
Bobsw32's Avatar
BobsW32
NAPA GOLD
I used to only use A/C Delco till one night after an oil change I went for a ride only to see my oil pressure go to "0" The oil filter had a pin hole leak in the side of the filter and emptied the oil
Old Jan 22, 2010 | 05:27 AM
That would be a total bummer!
Old Jan 22, 2010 | 07:48 AM
J-(Chicago)'s Avatar
Seasoned beater pilot.
I use a wix or napa gold 307 filter on everything. They are more slender than the big fat 350/455 filters.
I don't mind the k&N filters either but they always want too much $ for them.
Old Jan 22, 2010 | 11:12 AM
redoldsman's Avatar
Proud Viet Nam Veteran
Wix and NAPA Gold since it is the same thing. Good oil and good filters are cheap insurance. Olds64 I bet you have put a lot of money in your engine. Why jeopordize it for a few buck you will save on oil and a filter. I bet you Dad will tell you the same thing.
Old Jan 22, 2010 | 11:45 AM
Maybe I should change to Wix. I've used their oil filters on some of my other cars.
Old Jan 23, 2010 | 08:19 AM
84oldsDelta88's Avatar
I use a fram tough guard oil filter with my 307 fairly cheap at only maybe 5-7 dollars well worth it
Old Feb 25, 2010 | 09:29 AM
71 Cutlass's Avatar
One of None W-31
Wix
Old Feb 25, 2010 | 09:57 AM
henryk8398's Avatar
Hangin' out...
Anything made by Wix. That includes Napa Gold.
Old Feb 25, 2010 | 10:26 AM
380 Racer's Avatar
Originally Posted by henryk8398
anything made by wix. That includes napa gold.
x2
Old Feb 25, 2010 | 12:02 PM
Lady72nRob71's Avatar
Here is an in depth study of oil filters...
http://minimopar.knizefamily.net/oilfilters/index.html
Here are the final opinions from the tester:
http://minimopar.knizefamily.net/oil.../opinions.html
I have read through this before and most of the advice already given in this thread stands to agree with the test's conclusions. I looked into this deeply last year and actually looked at some filters at the store - I still agree with the tester's conclusions.
True, the AC delco filter WAS a good one, but not ones mfgd after 2008. I have ONE "good" Delco filter on the shelf - I will keep it as the "last of the good ones".
-Edit- The older ones are still out there - i found three at Oreilly's on 10-26-10! They have the 6 inlet holes and no "E" after the part number on the box.
The NEWER CRAPPY AC Delco filers can be identified by an "E" at the end of the part number (stands for Ecore (which stands for - get this - economy core!)) and 8 small inlet holes.
The Frams are mostly shunned, except for the toughguard. However, that black crap on the end crumbles, defeating its purpose of removing it easily.
Wix, Purolator, Napa, and Motorcraft seem to be the best popular filters.
Last edited by Lady72nRob71; Oct 27, 2010 at 09:46 AM. Reason: added AC Delco ID info
defiant1
Aug 26, 2011 09:45 AM
J'ville
Jul 10, 2009 03:18 PM
