1967 W30 OAI Track Pack Repro. air filter housing, hoses, duct work, NOS Air filter
Selling these functional, but not 100 percent correct, aftemarket reproduction parts used on the '67 W30. All of these parts are new & in the package. The air filter housing looks to be fiberglass with aluminum bottom & top with a new K & N air filter.
The hoses, clamps, & duct work are all new & in the package.
The box for the NOS AC A90CW is trashed, but the filter is new & in good condition.
I'd like to get $700.00 for everything plus shipping or pick up here in Indianapolis.
Scott
c. 317-727-7041
Scott
c. 317-727-7041
Last edited by oldspackrat; September 2nd, 2014 at 12:02 PM. Reason: Joe corrected me. :)
Also if someone were to ask, that AC 90cw filter is the standard filter used on most of the Oldsmobiles in that era. A true 67 W30 element would be the AC90c. The w stands for wet with oil for more dirt grabbing properties but restricted air flow just a tad so the W 30 did not use the oil wetted filter. This is what I have been told anyway.
Matt,
In the picture with the paperwork you can kind of see the template you'll need to cut the holes for the ducts. I might even have a core support from a '67 W30 with the holes already in them.
I'll await your call,
Scott
Scott
I believe that after market ram air kit uses a 14" air filter. The AC90 is not 14". As stated the AC90 is for a stock air cleaner housing, same as a 66 uses but not the OAI versions.
Does anyone know of a set of reproduction or similar ducts? I know the hoses are available and an aftermarket not factory air cleaner is available and I also know of the fiberglass ones that were around for a while. I am thinking I might like to add this on the 67 we are doing now. If anyone knows of a set of these please let me know.
I would prefer not factory as those should go to a correct factory car. While ours is a numbers original car, I would like to do this.
Email me if you have or know of any.
Larry
lemoldsnut@aol.com
Larry
lemoldsnut@aol.com
I am still looking for a reproduction air cleaner shroud for a 67 W30 please let me know if you have one.
Larry
direct email
lemoldsnut@aol.com
Larry
direct email
lemoldsnut@aol.com
Bernhard
April 27th, 2013 10:54 PM
oldspackrat
January 27th, 2013 07:00 PM
