Adjustable roller rockers
Old Jan 14, 2011 | 10:57 AM
rlang's Avatar
I'm installing Mondello's adjustable roller rockers on my 68 Cutlass 350. Is there a good procedure to follow in locating the base circle of each of the cam lobes with the intake manifold still on?
Old Jan 14, 2011 | 05:17 PM
BlackGold's Avatar
As you rotate the engine (by hand or starter), looking at just one cylinder at a time, you will see the exhaust valve open then close, then the intake valve open then close. At that point you can be sure that the exhaust lifter is on its lobe's base circle. Adjust the exhaust rocker.
Then rotate a little more. When you see the exhaust valve just start to open again, you can be sure that the intake lifter is on its lobe's base circle. Adjust the intake rocker.
Repeat for each cylinder.
Old Jan 15, 2011 | 09:14 AM
rlang's Avatar
Thanks Brian.....I'm on a steep learning curve on this engine stuff and didn't want to screw stuff up.
Russ
Old Jan 15, 2011 | 02:52 PM
captjim's Avatar
IMO, this is the best procedure on the Web,
http://www.cranecams.com/pdf-tech-tips/hydro-lift.pdf
Old Jan 15, 2011 | 03:09 PM
Rickman48's Avatar
When adjusting - look to see if the roller is centered on the valve - wasn't on ours, and we had to get custom length pushrods!
Also double-gasket the stock valve covers - they hit ours!
Old Jan 19, 2011 | 03:19 PM
rlang's Avatar
Thanks folks....as always, the expertise available to us shade tree guys through this forum sure elevates the confidence level! Appreciate the help.
Russ
Blownolds
Jul 5, 2018 10:35 PM
Xon
Sep 16, 2013 06:15 AM
timothypaul
Oct 26, 2008 08:03 PM
Redog
Aug 14, 2008 06:56 PM
70OLDS442
Nov 21, 2007 05:00 PM
