Ok littel confused / frustrated
Old Oct 16, 2010 | 10:21 PM
Limey's Avatar
I just installed the new to me built 350 and the block is from 1973 (code was verified) my old motor was a stock 1977 Cutlass original to car.
The 77 motor had a/c in car but was removed by previous owner, my problem none of the pulleys are in line, I have since measured both water pumps the 73 pump is 1/4" shorter than the 77.
I tryed every possible combo of old / new pulleys with no success the last step is to take the old power steering pump off from the 73 and switch mine for it ?? Any help would be greatly appreciated
P.S. I am assuming the 73 motor was a non a/c car for the it is only 14 and some change in diameter with 2 grooves for the belts, and the 77 motor w/ ac has 3 grooves for belt and is 16 and change in diameter
Old Oct 17, 2010 | 05:54 AM
Oldsguy's Avatar
Past Administrator
If you want AC you need to get a long snout water pump on the '73 and then with all the pulleys from '77 it should all fit. If you don't want AC you need to use the short water pump from the '73 or buy a new one for non-AC application and use all the pulleys from the "73 motor, if you have them. You can't mix n match.
Old Oct 17, 2010 | 09:20 AM
Limey's Avatar
Dan this is where I am getting stuck at I do not want the a/c and it has been removed, So I am using the smaller pulleys from the 73 and none of them line up and they came on this motor so I am assuming I have to change the power steering pump out to get the belts all to line up, For that is the only NON 73 pulley I have in the mix
Old Oct 17, 2010 | 09:52 AM
svnt442's Avatar
Use the water pump from the 77.
Old Oct 17, 2010 | 10:40 AM
Oldsguy's Avatar
Past Administrator
OH Ok, I got ya. I think you are going to have to get a PS pump pulley to match the '73 then.
Old Oct 17, 2010 | 12:54 PM
Limey's Avatar
problem is solved I had to get the power steering pump from the 73 and use it amazing how much 1/4" will throw a monkey wrench into the mix
and thanks to all who responded !!!
Old Oct 17, 2010 | 01:02 PM
Limey's Avatar
then I would have to disassemble the front half off the motor after just putting it back together but I solved the problem just snagged the power steering pump off the 73 and now works
Old Oct 17, 2010 | 01:03 PM
svnt442's Avatar
I saw that. I wasn't aware that you had all of that from the 73. Usually you just get the motor and not the p/s pump.
Old Oct 17, 2010 | 03:20 PM
Limey's Avatar
I didn't have it, but the guy I got the motor from did still have it so we just swapped out pumps
Old Oct 17, 2010 | 03:30 PM
svnt442's Avatar
That works.
Old Oct 21, 2010 | 11:03 AM
Limey's Avatar
That works.
Thanks for all the help guys
AND THIS IS THE FINAL RESULT
http://www.youtube.com/v/wkBB7SNa5FE
Old Oct 21, 2010 | 11:37 AM
Barry Jones's Avatar
Retard the timing a little and it will start easier.
Old Oct 21, 2010 | 11:42 AM
Limey's Avatar
right I did that already I forgot I had twisted it a little to clear the firewall I just forgot to take it back to where it needed to be is all ..........
but thanks Anthony
stonedglass
Nov 24, 2010 09:48 AM
Natas
Apr 22, 2010 07:30 AM
jensenracing77
Site Help
Feb 6, 2009 04:02 AM
southcarolina803
Jul 11, 2008 10:58 AM
Scotty B
Jul 4, 2008 10:12 PM
