Ok littel confused / frustrated
Old October 16th, 2010, 10:21 PM
Limey's Avatar
I just installed the new to me built 350 and the block is from 1973 (code was verified) my old motor was a stock 1977 Cutlass original to car.
The 77 motor had a/c in car but was removed by previous owner, my problem none of the pulleys are in line, I have since measured both water pumps the 73 pump is 1/4" shorter than the 77.
I tryed every possible combo of old / new pulleys with no success the last step is to take the old power steering pump off from the 73 and switch mine for it ?? Any help would be greatly appreciated
P.S. I am assuming the 73 motor was a non a/c car for the it is only 14 and some change in diameter with 2 grooves for the belts, and the 77 motor w/ ac has 3 grooves for belt and is 16 and change in diameter
Limey is offline
Old October 17th, 2010, 05:54 AM
Past Administrator
Oldsguy's Avatar
If you want AC you need to get a long snout water pump on the '73 and then with all the pulleys from '77 it should all fit. If you don't want AC you need to use the short water pump from the '73 or buy a new one for non-AC application and use all the pulleys from the "73 motor, if you have them. You can't mix n match.
Oldsguy is offline
Old October 17th, 2010, 09:20 AM
Limey's Avatar
Dan this is where I am getting stuck at I do not want the a/c and it has been removed, So I am using the smaller pulleys from the 73 and none of them line up and they came on this motor so I am assuming I have to change the power steering pump out to get the belts all to line up, For that is the only NON 73 pulley I have in the mix
Limey is offline
Old October 17th, 2010, 09:52 AM
svnt442's Avatar
Use the water pump from the 77.
svnt442 is offline
Old October 17th, 2010, 10:40 AM
Past Administrator
Oldsguy's Avatar
OH Ok, I got ya. I think you are going to have to get a PS pump pulley to match the '73 then.
Oldsguy is offline
Old October 17th, 2010, 12:54 PM
Limey's Avatar
problem is solved I had to get the power steering pump from the 73 and use it amazing how much 1/4" will throw a monkey wrench into the mix
and thanks to all who responded !!!
Limey is offline
Old October 17th, 2010, 01:02 PM
Limey's Avatar
then I would have to disassemble the front half off the motor after just putting it back together but I solved the problem just snagged the power steering pump off the 73 and now works
Limey is offline
Old October 17th, 2010, 01:03 PM
svnt442's Avatar
I saw that. I wasn't aware that you had all of that from the 73. Usually you just get the motor and not the p/s pump.
svnt442 is offline
Old October 17th, 2010, 03:20 PM
Limey's Avatar
I didn't have it, but the guy I got the motor from did still have it so we just swapped out pumps
Limey is offline
Old October 17th, 2010, 03:30 PM
svnt442's Avatar
That works.
svnt442 is offline
Old October 21st, 2010, 11:03 AM
Limey's Avatar
That works.
Thanks for all the help guys
AND THIS IS THE FINAL RESULT
http://www.youtube.com/v/wkBB7SNa5FE
Limey is offline
Old October 21st, 2010, 11:37 AM
Barry Jones's Avatar
Retard the timing a little and it will start easier.
Barry Jones is offline
Old October 21st, 2010, 11:42 AM
Limey's Avatar
right I did that already I forgot I had twisted it a little to clear the firewall I just forgot to take it back to where it needed to be is all ..........
but thanks Anthony
Limey is offline
stonedglass
November 24th, 2010 09:48 AM
Natas
April 22nd, 2010 07:30 AM
jensenracing77
Site Help
February 6th, 2009 04:02 AM
southcarolina803
July 11th, 2008 10:58 AM
Scotty B
July 4th, 2008 10:12 PM
Quick Reply: Ok littel confused / frustrated
