Timing dots
Timing dots
how are the dots on the timing gears supposed to line up at top dead center. both dots up? pointing at each other? ect.....kinda confused right now and tore it apart and dont recall. thanks for the help!!
350 if it matters.
350 if it matters.
Both. Since the crank turns twice for every one revolution of the cam, the dots will be lined up correctly in both places.
If the camshaft dowel pin is straight up, the timing mark on its gear is down, and the camshaft is at "overlap" #1 TDC, meaning the exhaust valve is closing and the intake valve is opening. If the dowel is down, the timing mark is at the top of the gear, the engine is at #1 firing TDC.
You can put the chain on the gears either way, but if you put the distributor in with the cam dot at 6 and crank at 12, you are at number 6 at TDC. Need both to be at 12 Oclock to put the distriburtor, at # 1 cylinder.
65OldsDelta88SuperRocket
Nov 23, 2011 09:22 AM
